Thread: Battery mounts...
Old 11-22-2008, 04:15 PM   #1
Default Battery mounts...
Thinking i am ditching the split battery plates for a servo/battery mount... any one better than the other? i have seen carbon fiber, etc. How is the ckrc viper mount?
Deezul is offline   Reply With Quote
Old 11-22-2008, 05:03 PM   #2
TSK
Shelf queen
TSK's Avatar
From what I've heard, the split pack is supposed to provide a better l to r weight balance. i still prefer a normal servo/battery mount like the carbon fiber one I currently use from 3Racing. Ultimately I think it comes down to what type of battery you run since I doubt any lipos will fit on a split pack batery mount.
TSK is offline   Reply With Quote
Old 11-22-2008, 05:54 PM   #3
could you let me know why you are ditching the split packs. I am only a newbie and have just started making my own split packs ,to me they seem to help heaps with lowering my cog and improving my rigs handling so I am curious as to why you want to change.
523revo is offline   Reply With Quote
Old 11-23-2008, 12:29 AM   #4
the only reason to ditch the split pack would be for lipo.... thats what i did. i couldnt find a lipo capacity that i liked to keep it split. more fab work time!
BuzzKilla is offline   Reply With Quote
Old 11-23-2008, 02:26 AM   #5
I didnt consider li-pos. i have a rtr and cant afford a decent esc so switching to li-po is the one reason for getting rid of split packs i didnt think of
Old 11-23-2008, 05:11 AM   #6
I really like my CKRC viper link mounts dont know about the battery mount though.
-WHEELMAN- is offline   Reply With Quote
Old 11-23-2008, 06:07 AM   #7
I like the 2 3 pack better it lowers the weight better balence but if want to change talk to chris the battery man[ cheapbatterypacks.com ] great to talk to.but my choice is the 2/3 pack
blacksmith is offline   Reply With Quote
Old 11-23-2008, 10:00 AM   #8
looking to switch because 1 i want to change the linkage and 2 lipo MIGHT be in the future......
Old 11-23-2008, 10:36 AM   #9
TEAM MODERATOR
Reflection's Avatar
I've used this one in the past and it worked very well. http://rcpcrawlers.com/product.php?p...&cat=29&page=1
I was able to put a servo and a 1350 mah 3 cell on there with no issues.
Reflection is offline   Reply With Quote
Old 11-23-2008, 11:04 AM   #10
When crawling with lipo batteries keep in mind not to dammage the pack. lipos are easily dented and punctured, these types of dammage cause internal shorts which kill the battery. It is easy to cause this type of dammage with the pack on the front axel.
To avoid this issue I have my ESC mounted next to the servo on an offset plate, my battery is mounted on the upper "Y" link of the suspension to keep it out of harms way.
nathanschmoekel is offline   Reply With Quote
