Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: ax 10 issue with speed control
Old 12-06-2008, 05:34 PM   #1
Default ax 10 issue with speed control
new to this site just trying to get some help.why is my rig at low throttle not wanting to creep it just wants to jerk or go wide open ,wondering if speed control is bad.
bukithead is offline   Reply With Quote
Old 12-06-2008, 05:37 PM   #2
well what speedo and radio are you using?
roninwarrior555 is offline   Reply With Quote
Old 12-06-2008, 05:45 PM   #3
Default ax issue
just got this rig 3 weeks ago ,im still running stock radio and speedo
Old 12-06-2008, 08:50 PM   #4
my truck was a bit jerky at random times with a traxxas radio setup and the rooster crawler...ive switched to a futaba radio and it seems to have cleared up almost 100%
booger weldz is offline   Reply With Quote
Old 12-06-2008, 11:54 PM   #5
so it's an RTR?
i was using a airtronics blazer and a LRP runner in my rig but sense the dig unit went in i have a tq3 and it seems to work very well.
my super now has the blazer and a rooster crawler.
Old 12-07-2008, 12:02 AM   #6
I'm having the same type of problem with my rig, I'm running the Novak Rooster Crawler ESC, Novak 55 turn motor, and an Airtronics MX-3 FM radio. At very low speeds I get a jerky glitch, but it olny seems to happen every few minutes and is kind of random. I've changed my freq crystals, re-routed the wiring, moved the receiver to a different location away from the ESC and motor, all with no change.
Bustedback is offline   Reply With Quote
Old 12-07-2008, 10:41 AM   #7
My RTR did did that too. have you played with the trim and throttle position? i got mine to work pretty good eventually then I bought a rooster crawler setup.
ax10alex is offline   Reply With Quote
Old 12-07-2008, 01:53 PM   #8
I had this problem when I went to my Castle Mamba Max. Went with an M11 with Specktrum SM1000 and never looked back.
Jonnie Fraz is offline   Reply With Quote
Old 12-07-2008, 03:21 PM   #9
Talking speed control
i think i got it working better . i took every thing apart and blew it out with cleaner. seems to work o.k. now,thats alright buying new rooster this week.
can not have this type of performance .well back to making saddle packs for now . try to get some pics of rig and my back crawler course on soon.
Old 12-07-2008, 04:16 PM   #10
Moonbuggy Berg
treday619's Avatar
I would also put a smaller spur gear a 9t. I think with the RTR is comes with a 14t and I am not on the other one. That will also help with the jerkiness of the truck
treday619 is online now   Reply With Quote
Old 12-07-2008, 04:30 PM   #11
I am having the same issue with my rtr with all stock electronics. After rerouting the wiring and moving the receiver it was still happening. I did notice that mine is more jerky when i have the wheels turned and the steering servo is under load. I've read that certain servo's can cause interference with cheaper radio's. I ordered a dsm spektrum radio/receiver. Hopefully it helps.
dj23gsx is offline   Reply With Quote
Old 12-07-2008, 05:18 PM   #12
Default ax issue
thats funny you said that,because i didnt notice anything different until i changed the stock axial steering servo with a futaba servo.
