| | #1 |
| Quarry Creeper Join Date: Dec 2007 Location: ON THE "EDGE"
| when moving the lower links to the center of the skid and outboard on the axle, I shortened my wheelbase from 12.5 inches to just under 12 inches. Do I just use longer rod ends to compensate for angling the lower links? |
| Sponsored Links | |
| | #2 |
| 2D ![]() Join Date: Mar 2008 Location: Dodging Bullets
| or spacers. |
| | #3 |
| Rock Stacker Join Date: Nov 2008 Location: oakdale
| no probs with driveshaft/lower link clearance on articulation? ive always run this setup on my 1:1 crawlers with excellent results...seemed to be an a tight fit on the scorpion chassis though?? |
| | #4 | ||
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| | #5 |
| wow, that chassis setup is skinny! didnt you used to wheel 1:1's and post on pirate4x4 alot? i bet you THOUGHT this hobby was gonna be cheaper...LOL! those aluminum 'rings' on the rear section of your driveshaft for a dig setup? good idea!!! |
| | #6 | |
A skinny chassis has a skinnier drag path,so to speak. Less to hang on and lets you squeeze between objects easier. That is my old drive line dig set up. It's actually a piece of stainless turned down and made to work with Pede shafts. I got tired of twisting shafts off,so I made the male section on the axle end out of steel. Worked pretty good for a while. I've built me a tranny mounted dig now and it works 100% better. | |
| | #7 |
| yeah, remember 4runrick? hes got a link to build a driveshaft dig setup like you have pictured, but i ended up buying the rc4wd r2d tranny from trail gear(they sell RC stuff for axial rigs now!!)...got any links to your RC builds? i know you can build a good 1:1 truck, so id like to steal your ideas on a smaller scale |
| | #8 | |
| Quote: | |
| Thread Tools | |
| Display Modes | |
