Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: fuel line with big bores
Old 12-07-2008, 12:49 AM   #1
Default fuel line with big bores
i know i saw a thread on how to mount big bores on a stock ax10 with fuel tube but can not find it. anyone have a link or pic? thanks
AWILLIAMS64 is offline   Reply With Quote
Old 12-07-2008, 12:53 AM   #2
MWRCA'er
Mnster's Avatar
The bushing things at the fluid cap?
I just use stripped off wire insulation.
Mnster is offline   Reply With Quote
Old 12-07-2008, 01:00 AM   #3
i used a bit of fuel line from my 8th scale
hyhflo is offline   Reply With Quote
Old 12-07-2008, 01:08 AM   #4
thats a good idea too, i have lots of that!
will the inserts not fit in these shocks from the stock shocks? i have not checked yet
Old 12-07-2008, 02:29 AM   #5
MWRCA'er
Mnster's Avatar
Not sure but the rubber bushings help it to have more flexiblity and not bind.
I've tried fuel line but everything I could get my hands on was 1/4 or bigger and wouldn't fit.
Old 12-07-2008, 02:30 AM   #6
Befriending Champ 09'
crunky's Avatar
slice it down the center... no ?
crunky is offline   Reply With Quote
Old 12-07-2008, 02:33 AM   #7
MWRCA'er
Mnster's Avatar
Kinda hack...
Allows it to bunch up on either side of the shock cap and slip out. The hole inside the tube is already under 3mm. I've used it in a pinch before but the wire insulation is perfect. For losi shocks with the huge holes I bet fuel line would be a perfect fit.
Old 12-07-2008, 07:40 PM   #8
just use some gas hoes from any 10th or 8th scale thats what i did and it worked great
merrillon24s is offline   Reply With Quote
