Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Checking axle alignment
Old 12-07-2008, 10:10 AM   #1
Default Checking axle alignment
i was looking at my crawler and the rearend does not look straight.
my question is this How do I measure to see if its all in line?
Knuckle to Knuckle or just eyeball it
hyhflo is offline   Reply With Quote
Old 12-07-2008, 10:19 AM   #2
What's In The Box!!!!!!!
Lil Jon's Avatar
one of your links probably pulled out a bit. see if all your links are tight and in the same holes on the chassis
Lil Jon is offline   Reply With Quote
Old 12-07-2008, 10:21 AM   #3
ya, take the wheels off and measure from wheel hex to wheel hex, if your links are the same and chassis is not bent the distance should be the same
ax10alex is offline   Reply With Quote
Old 12-07-2008, 11:28 AM   #4
Old 12-07-2008, 11:29 AM   #5
If you can see through the fog that is where my end has to be to make axle square?
maybe put a washer in there?
Link is short?
Old 12-07-2008, 11:40 AM   #6
Lil Jon's Avatar
the link is probably bent. is it a straight link or high clearance? if it is a straight link take it off and roll it on a flat surface so u can se where it's bent
Old 12-07-2008, 06:52 PM   #7
I've also seen bent links get bent more after a fall. Take the two of them off and lay one on top of the other to check them.
allgm1 is offline   Reply With Quote
