Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: HR Dig or RC4WD Transmission
Old 12-07-2008, 04:43 PM   #1
Default HR Dig or RC4WD Transmission
OK Which to go for? Any opinions on which is the better spend?
http://www.tcscrawlers.com/RC4WD-R2-...3-p-16468.html
or
http://www.tcscrawlers.com/Hot-Racin...1-p-17172.html
Arct1k is offline   Reply With Quote
Old 12-07-2008, 05:04 PM   #2
From what I've personally used, the ax-10 transmission is way better than RC4WD's, so I would use the HR or DNA dig. I just installed the DNA in my AX-10 and carefully followed the instructions, and I LOVE IT!!!!!!!! People who have burnt up servos had some binding somewhere or didn't follow the instructions, period.
RaleighRCer is offline   Reply With Quote
Old 12-07-2008, 05:51 PM   #3
I went with what was cheap and in stock, the CKRC Dig setup. The part quality wasn't that good. But after smoothing and polishing the moving parts and some extra shims, it's actually pretty good.
ForkliftJeff is offline   Reply With Quote
Old 12-07-2008, 06:18 PM   #4
stock axial tranny, and buy and install the VF/DNA Dig. it comes with hardened output shafts for the tranny, then install the dig. i think you ll find the VF/DNA much nicer to work with, install and use over the other Dig options..
Timmahh is offline   Reply With Quote
