Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Newb Needs Help
Old 12-08-2008, 11:09 AM   #1
Unhappy Newb Needs Help
i was wheelin yesterday and after about an hour of wheelin i got bound up in some rocks and it sounded like my tranny was slippin and when i looked at it the pinion gear would spind but the larger(spur gear i belive) was slipping. when i would drive in reverse though it would be fine... is it cuz its nylon or is my tranny slippin.... i need help i want to crawl again:-(:-(:-(
bmxcrawler is offline   Reply With Quote
Old 12-08-2008, 11:16 AM   #2
help a buddy out
Old 12-08-2008, 11:52 AM   #3
Sounds like you need to re mesh your motor to spur gear . Back off the 2 motor mount screws , and re mesh and re tighten , all should be good again .
outlikealight is offline   Reply With Quote
Old 12-08-2008, 11:53 AM   #4
Wait you have the same question posted twice. Dude lay off the coffe or crack people will respond.
thunder7845 is offline   Reply With Quote
