![]() | #41 |
Newbie Join Date: Dec 2008 Location: Otsego, MN
| ![]() Waterproofing is never perfect but I've waterproofed both mine and my roommates axials. At first I ballooned everything but they got holes and I fried the esc. Small plastic boxes like tuperware are good. Leave enough room so the electronics can breath (I haven't had any problem with a baloon on the servo). Cut a notch in the plastic for the wires. Put on the top and put some silicone sealant around the wires to fill the notch. Once you start driving through water It will all be worth it.
![]() | #42 | |
Pebble Pounder Join Date: Jun 2008 Location: Kalispell
| ![]() Quote:
I have switched to panthers for the extra height...but I prefer the tractability of my aired up claws over the panthers any time ground clearance isn't an issue. | |
![]() | #43 |
Newbie Join Date: Mar 2009 Location: Victoria BC
What's this I hear about "zip tied driveshafts???"
![]() | #44 |
Newbie Join Date: Feb 2009 Location: sonoma
this is my first post so bear with me if my pics dont show up the first try. I used the extra t-case peices (or whatever they are) that came with my AX10 as battery trays on the front axle |
![]() | #45 |
![]() | #46 |
Quarry Creeper Join Date: Jan 2009 Location: longwood, fl
Tires are a huge upgrade for the axial, You can do al the suspension mods you want but if you cant hook up your not going anywhere
![]() | #47 |
also you can see I used the spacers to raise my steering a bit. every inch counts |
![]() | #48 |
I broke a driveshaft and noticed another was twisting. the local shop sells packs of 5 t maxx drive shafts I think for 9.99. they turned out to be a bit short so I made this. |
![]() | #49 |
Newbie Join Date: Mar 2009 Location: Parry sound, Ontario, Can
just to let people know duratraxx mini quake springs fit perfect in ax10 shocks as internals
![]() | #50 |
Rock Stacker Join Date: Jan 2009 Location: OZ
I haven't gotten my AX10 finished yet, too much other stuff came up. Can someone tell me on a stock AX10, what the measured distance is between the inside of the rear tire to the inside of the tire opposite of it ? ( both are rear tires, not rear to front tire ) Thanks |
![]() | #51 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
EXTREMELY cheap tech. Tip for keeping the rock grabbing aluminum from hanging you up on the rocks. Just unscrew one of the rod ends off the link and slide the body of a "Bic" style pen (or some of the cheap click ones like from a bank) over the link and as close to the end of the rod as you can then screw the end back on. walla you've got a great slider that cut down the friction and makes it easy to glide over the rocks. You can use colored ones too and get rid of the hidious green and a 48 pack of pens from Office Depot is only $3. You can slide them over the bent links as well, it just takes a little pushing but they will go over them. My rear links on my tuber are stock AX10 bent with plain white pen bodies pushed over them. Slides over the rocks like butter now. Top custom rear links were covered by some bank pens just to cover up the ugly fadded color and extention job. |
![]() | #52 |
Newbie Join Date: Mar 2009 Location: ithaca
thats a good trick for the links....now whar did i put that pen ![]() |
![]() | #53 |
Newbie Join Date: Sep 2008 Location: Watsontown
so, when my shocks go into full or even close to full droop, my spring has no tension,.. leaving the lower spring retainer loose, and somtimes falling out, now, if i were to flip my shocks and flex at all...they would just fall right down....any tips on what i can do to keep them put on the shock mounting piece.
![]() | #54 | |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
| ![]() Quote:
get to much twist on the screws that go thru the knuckle. It will eventually twist the screw out of the knuckle. Or it will bind up and break. ![]() | |
![]() | #55 | |
| ![]() Quote:
put a ziptie on the piston rod above the retainer. ![]() | |
![]() | #56 | |
Pebble Pounder Join Date: May 2008 Location: Va Beach
| ![]() Quote:
Excelent idea!!!!!!!! Im all over this! Mine are getting pretty war torn and they catch more than when they were new obviously. Definately putting this to use! | |
![]() | #57 | |
Newbie Join Date: May 2009 Location: New Zealand
| ![]() Quote:
![]() | #58 | |
Quarry Creeper Join Date: Jul 2007 Location: Fort Mill, SC
| ![]() Quote:
that is AWESOME! It is a great study/proof for 1:1 cages too! I assume it is a home-made cage/chassis? What about the axles? They plastic? I know it may not be anyones' here... just wondering if anyone knows.... Thanks for posting that! ![]() | |
![]() | #59 | |
Newbie Join Date: May 2009 Location: Hertfordshire, UK
| ![]() Quote:
Cheers | |
![]() | #60 |
