![]() | #61 | |
Pebble Pounder Join Date: Apr 2006 Location: Newton
| ![]() Quote:
Not trying to call you out man, but this has gotta be the most lame thing I've ever heard. It's not like you're running enough tire pressure to even notice, and furthermore atmospheric air pressure will be captured in a closed environment. Your AC just ain't gonna cut it. If that was the case Pep Boys needs to trash their equipment and just start mounting tires inside the store. ![]() | |
![]() | #62 |
Pebble Pounder Join Date: Apr 2009 Location: tn
some people like it ive heard GT 2.2 " Air System Beadlocks (2) for 2.2inch Size Tires Fit truck with 12mm wheel hex ![]() ![]() GT 2.2" Air system beadlock wheels can adjust air pressure easily for tire performance over all kind of terrain. Beadlock wheelslock directly onto the tire eliminating the need for gluing your tires and keeping the rims reusable. |
![]() | #63 | |
Newbie Join Date: Apr 2009 Location: Bay Area
| ![]() Quote:
![]() | #64 | |
Newbie Join Date: Jun 2009 Location: Sydney
| ![]() Quote:
I know I used to have to check my tyre pressure before each stage when I was competing in rock crawling in my buggy because leaving a couple of tyres out in the sun would create a pressure increase, and that's on a 40" tyre. | |
![]() | #65 | |
| ![]() Quote:
I'm still saying no to this. We are talking about toy sized tires going toy sized speeds. I take my 1:1 Toyota hybrid on the trail all day and when I'm done and load it back on the trailer I'm still at 10psi. Rock crawling is slow, street racing is fast. Fast speeds will build pressure within the tire. If you generate that kinda heat rock crawling you need to rethink your hobby. ![]() ![]() | |
![]() | #66 | |
| ![]() Quote:
I know I'd set a rear tyre pressure of 6-7 first thing in the morning before competition started, then check it at 10:30 as I was about to begin the first stage and being sitting out in the sun and see it up over 10psi, let it down. This is just from sitting in the sun, not driving at speed. Check it again around lunch time and it's back up again. Come night time, the tyre will be sagging. I don't see why it wouldn't work on a smaller scale. Since you posted a pic of your 1:1 I might post one of mine ;) ![]() and generating heat in the front tyres ;) ![]() but now we're getting a bit off topic Last edited by maddog; 07-08-2009 at 05:26 PM. | |
![]() | #67 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
well really your both right... we all know cold air is denser then warm air any one knows that, how ever the the tempiture differance that one would get from an AC unit wouldnt be enought to make the tire firm when it warmed up, the pressure increase would still happen but would be very miniscule... now if one were to put the tires in the freezer for 30min or so with 1 bead lock ring removed and then assemble them while still in the freezer and let it warm up you would notice a vert large increase in pressure
![]() | #68 |
Newbie Join Date: Nov 2008 Location: evansdale, IA
instead of air and instead of memory foam in my rock claws I bought a $6 teddy bear..... ![]() worked awesome just enough flex and sidewall strength ![]() |
![]() | #69 |
Newbie Join Date: May 2009 Location: owatonna mn
wow teddy killer...you could have just went to wal-mart and got a thing of cotton for 2 bucks ![]() |
![]() | #70 | |
Rock Stacker Join Date: Jun 2007 Location: Abbotsford BC
| ![]() Quote:
![]() | #71 |
![]() | #72 | |
Newbie Join Date: Jul 2009 Location: Pacifica
| ![]() Quote:
![]() | #73 | |
Pebble Pounder Join Date: Jul 2009 Location: Lehigh Valley, PA
| ![]() Quote:
![]() | #74 |
Newbie Join Date: Jul 2009 Location: casper
not to but my nose in on this tire thing , but putting it in front of the A/C wont do anything, pull one side of the beadlock off and stick it in the freezer for an hour, try to keep it puffy as you put it back on and after it warms back up it will have extra presser in it but they still mold to the rocks.........but i still like my cut foam, so you can keep your air..........:-P
![]() | #75 |
Pebble Pounder Join Date: Jun 2009 Location: Jackson
![]() | #76 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
When running the antenna for the receiver, you can use the small straws for the coffee that you can get for free in any convieniance store. They are small and shorter, but you can make tight corners with them by just cutting the lengths you need to route the antenna.
![]() | #77 |
Quarry Creeper Join Date: Aug 2009 Location: Philadelphia, PA
That's a great idea, I will have to give that a try. My current mounting location give me gives me glitches or it might the cheap TQ 3. :?
![]() | #78 | |
Quarry Creeper ![]() Join Date: Aug 2009 Location: Snohomish, WA
| ![]() Quote:
I use 8oz lead-strap decoy weights for my tires. You can get them in 4oz, 6oz, or 8oz. I run 2x 6oz in each tire and it made my crawler climb better than ever! If you go this heavy, make sure you have the power to push em. I use JR 8711 servos and they have no problem what so ever... | |
![]() | #79 |
Newbie Join Date: Dec 2008 Location: Issaquah, WA
fowlboy where can i get these decoy weights?
![]() | #80 |
Pebble Pounder Join Date: Nov 2006 Location: vaca, nor cal
| ![]() Most hunting stores should have them, but look for the strap type not the nail type. http://www.basspro.com/webapp/wcs/st...2-_-3434493175 |
