06-11-2010, 12:29 PM | #121 |
Newbie Join Date: Sep 2007 Location: batavia
i dont know if this is the answer im just putting it out there Dubro Heavy Duty Ball Links? |
06-11-2010, 12:30 PM | #122 |
06-11-2010, 12:32 PM | #123 |
these are the one your really looking for http://www3.towerhobbies.com/cgi-bin...?&I=LXJGU3&P=7 |
06-18-2010, 08:48 PM | #124 |
Totally Cool Guy Join Date: Jun 2010 Location: In between Michigan River Rocks
i used the low cg batterie plate on my rtc and placed 3of 6 cells on that and 3 on the reg batterie plate and also my radio just puting that out there |
07-03-2010, 04:20 PM | #125 |
Newbie Join Date: Sep 2009 Location: Scottsdale
Just finished making this, don't criticize how it looks because i made it all with hand tools and not with some fancy benders or anything, i bend it using a vice. I think it looks pretty good and it does the job very well, also incorporated the inside the chassis link mod. |
07-04-2010, 08:02 AM | #126 | |
Newbie Join Date: Jul 2010 Location: Haydenville
http://www.youtube.com/watch?v=t_lQXDzS3pA Trust me this guy knows what he's talking about. Check out his other video's to he's got a ton of info in them. | |
09-21-2010, 12:55 PM | #127 |
Quarry Creeper Join Date: Nov 2007 Location: Cincinnati
looks good, papi. supposedly, cutting board is better material cause it slids over the rocks better. kick ass job, though, not all of us have access to cnc lathes like a lot of the members here seem to have. |
10-22-2010, 07:56 AM | #128 |
Rock Crawler Join Date: Feb 2010 Location: chin ckeck
| 55t motor the wrong way
jpg.gif Video 7 0 00 15-26.jpg (55.6 KB)
11-18-2010, 04:49 AM | #129 | |
Newbie Join Date: Nov 2010 Location: Cape Town, South Africa
Length of a receiver antenna is tuned to the circuit's dynamics. That's why you'll find in most manuals, it says DO NOT cut it. | |
11-18-2010, 06:19 PM | #130 |
Pebble Pounder Join Date: Jun 2010 Location: Farmington
| He never actually says to cut the wire, just the mast. but then he says not to cut the mast... and then says dont cut it till you need to cut it...
12-16-2010, 08:53 PM | #131 |
Pebble Pounder Join Date: Nov 2010 Location: flagstaff
| quick ride height change uses 8 chainlinks from bike chain 8 screws 3mm 8 3mm lock nuts remove shocks from top of chassis insert screw with links one on each side of chassis tighten alittle then install shocks it will move shocks out alittle it helped me with stability alot an aquick half inche up or down give it a try works great |
12-21-2010, 06:39 PM | #132 |
Quarry Creeper Join Date: Jun 2010 Location: Ravenna/ Sault Ste. Marie
for a 1/2 and 1/2 sprung/droop spring setup, use the internal springs from a venom in stock axial springs
01-12-2011, 03:17 PM | #133 | |
Newbie Join Date: Aug 2010 Location: Lake County
you will need 2. i got solid core for the front and holow core the the rear. i wraped my stock ax-10 rims with the lead roll,then wraped that tight with electical tape. worked great for me and seems likr a better and cheaper way to add wieght to your wheels. | |
01-12-2011, 03:30 PM | #134 | |
you can get it at any parts store for around $8. this is a grease that is safe for electronics and keeps water out. just fill your esc,servo and receiver with Di-electric compound and if it makes you feel better wrap a ballon around it and no water will ever get in you can also fill your trans and diffs with it. lube and repell water all in one | |
01-12-2011, 06:14 PM | #135 |
Rock Stacker Join Date: Jan 2011 Location: Travelers Rest
I'm looking at upgrading my shocks and see the popular choice is the taxxas big bores... Does anyone have the part numbers for the shock sets? When I search all Im seeing is to run the traxxas shocks not the part numbers...
01-12-2011, 06:18 PM | #136 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
Asuming it's the same big-bores as my slash the part is 2660 http://www.buytraxxas.com/product_in...roducts_id=554 |
02-01-2011, 07:24 PM | #137 |
Newbie Join Date: Jan 2011 Location: olathe
it comes with a top link bracket like a triangle, mount that to the front top link, make a rear one like it , and mount to the rear, put the esc on the rear and the reciver on the frount zip tie the wires to the frame to avoid that nasty tranny gear lol but it put lil oz. on the rear ohhh and i also have a split battery pack on the front just a lil tip instead of mounting it to the side of the tranny like some people ..... and all the wires reach fine
03-09-2011, 09:32 AM | #138 |
Newbie Join Date: Mar 2011 Location: CANON CITY
| home made bent links
i bent my stock lower links by bending them on the bench over a tire iron. worked great and they look just like the ones that you can buy!!!
03-20-2011, 10:38 PM | #139 |
Newbie Join Date: Dec 2010 Location: sacramento
| shock mounts
Vanquish makes some brackets to mount shocks up higher on axle and move in the suspension arms I think they are $15 per axle
04-12-2011, 01:49 PM | #140 | |
Newbie Join Date: Apr 2011 Location: SLC
| New Servo? Quote:
