05-15-2011, 03:46 PM | #141 |
05-29-2011, 02:48 PM | #142 |
Rock Stacker Join Date: Jan 2011 Location: grass valley ca 530
good tips i just got an ax10 its pretty fun will probably do a few of these tips
06-01-2011, 01:09 AM | #143 |
Rock Stacker Join Date: May 2011 Location: Salt Lake City
| BEEF TOOBS!!! and weighted rims
weight your rims with tire weights and install beef toobs!!
06-21-2011, 08:04 PM | #144 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
| Drive shaft mod
Drive shaft mod. I use stock Axial steel u-joints and Axial drive shaft rings. I use two female pede shafts and 1 male shaft with the yoke end cut off. I screw 8-32 thread-all into the male shaft to prevent twisting. According to the needed length, I shorten one of the female shafts. I used a set screw to hold the male shaft in place. |
07-11-2011, 01:32 PM | #145 |
Rock Stacker Join Date: Sep 2009 Location: chehalis
best tip of all is preventive maintnice
07-14-2011, 11:12 AM | #146 |
Pebble Pounder Join Date: Apr 2011 Location: scranton
some thing my friend did was for wheel weights get big washers and just lay the stock bead lock plates over it and drill the holes and its a weighted meaner bead lock |
07-22-2011, 12:05 AM | #147 | |
Yes, good job.... Last edited by Natedog; 08-02-2011 at 09:59 AM. | |
07-22-2011, 02:48 AM | #148 | |
Quarry Creeper Join Date: Nov 2010 Location: grand rapid mich.
08-21-2011, 03:42 AM | #149 | |
Pebble Pounder Join Date: Oct 2009 Location: Australia
I'm noob doing first build do i gain anything by making one axle narrower than other and which front or rear?any knowledge will be appreciated I'm use ax10 so can wiring it by use one 1/8 Axel they both steer and drive they have moa's on them so have own power i just have to pair motor a like. | |
10-26-2011, 01:28 PM | #150 | |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
Great Mod... Even better as I had some alloy T-Maxx shocks in my spares box... 30w oil works a treat . . But the Stock Traxxas Red Springs are still abit stiff, whats the best springs to use... Sean Last edited by West Cork Basher; 10-26-2011 at 05:28 PM. | |
04-30-2012, 03:22 PM | #151 | |
Rock Stacker Join Date: Apr 2012 Location: eastern gorge
| Re: Axial tips and tricks Quote:
that is probably the best mod i have seen for the stick battery | |
05-04-2012, 01:27 AM | #152 | |
Newbie Join Date: May 2012 Location: Huntington
thanks man, im definitely gonna try that! | |
05-06-2012, 10:44 PM | #153 |
a easy way to make scale bungee straps without havin to spend 20 bux on 6 scale bungees is to buy a box of paper clips, and a pack of the bungee type girls hairbows... u will need a set of wire cutters, and needle nose pliers.. Step 1: cut the hairband in half, or to desired length. Step 2: Straighten then paper clip out Step 3: Grab paper clip at the end w needle nose pliers, bend it making a small u shape Step 4: Put a end of the hairbow in between the u bend in hairbow and needle nose pliers Step 5: Start bending/twisting the paper clip around the end of hairbow about 5 times Step 6: Use needle nose pliers to bend the top of the paper clip into a u/hook shape, then snip off the excess Step 7: Squeeze the bottom end of paper clip w pliers to hold it snug in place, then tadaaa! home made scale bungee straps for cheap lol.. if you have any questions or need better specific instructions then feel free to message me and ill be happy to help you in anyway i can! |
06-04-2012, 08:06 PM | #154 |
Newbie Join Date: May 2010 Location: Jackson
| Cheap weights to stock rims
I am not the original person who came up with this idea but I felt it was a cheap upgrade to post. To add some cheap weight to your stock rims, buy 16 1/4-20 button screws at 1/2" long and 16 1/4 nuts. They fit real nice and cost me $3 for all the hardware.
07-29-2012, 01:12 PM | #155 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
well was gonna post up in the ax10 thread... i had one shock that kept popping on me.. i know everyone is going bigbore shocks with cap mod.. but for those of us that dont want to do that yet as we have other things to buy first... try this.. i used regular white pipe dope tape... u know this stuff PTFE Thread Sealant Tape by ANTI-SEIZE - Pipe Sealant Tape by Zoro Tools Industrial Supplies i put a few wraps around the threads of my rear shock that was falling apart... viola... all better.. no more popping apart |
07-31-2012, 03:56 PM | #156 |
Newbie Join Date: Jun 2012 Location: Australia
If your shocks are popping apart try a different mounting point. I run mine on the outer most upper mounting hole and have no issues, if I mount one hole further in they will pop apart. Cheers
09-07-2012, 09:26 PM | #157 | |
Newbie Join Date: Aug 2012 Location: chattanooga
09-09-2012, 11:56 PM | #158 |
Newbie Join Date: Jan 2012 Location: Ingram
Great tips!
02-05-2013, 01:36 PM | #159 |
Quarry Creeper Join Date: Jan 2008 Location: Hellsberry
This is an old one, but I didn't see it in here: notch your skidplate and put your lower links on the inside of the chassis. Use button head screws to keep from hanging up on rocks. Doing this also helps with link triangulation which lowers the amount of torque twist.
03-25-2013, 09:27 AM | #160 |
Pebble Pounder Join Date: Mar 2013 Location: Albuquerque
so much good info for a newb..Thanks
