01-01-2009, 09:24 PM | #1 |
Pebble Pounder Join Date: Dec 2008 Location: MIDDLE TN.
| Suspension on new AX10 RTR to stiff
I bought a new RTR yesterday,the suspension is way too stiff (won't flex like I think it should.)I'm comparing it to the one I got my son for X-MAS (used),I think it was built from a kit.It has a lot of upgrades,alum links,green alum bead locks,servo,55t motor,speed control Rock Crawler tires,which are way softer tires.The shocks and springs look the same as on mine ,light gray springs.I've put 20 wt. oil in my shocks trying to soften them,but it didn't help much.Can I trim a coil off the spring to soften it or get different springs?Also can I trim the foam or split the foam in the tires to soften them up? THANKS JEFF |
01-01-2009, 09:56 PM | #2 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
The color type of the spring is on the end. I think the stock rtrs are blue. It should be a little tripe on the end. And if you are using the stock tires I would suggest star cutting the foams. Some guys dont like it but it does the trick in a pinch. And as for springs, the options are endless, if it fits use it. I used E-maxx springs and with a little tweaking it worked out great.
01-01-2009, 10:08 PM | #3 |
Your're right,I looked at them and they are blue on both crawlers.Can't figure out why the suspension on my sons crawler is so much softer.I may try ordering some of the soft or super soft springs. THANKS JEFF |
01-01-2009, 10:16 PM | #4 | |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
your sons might have been a kit and it probly had some mods | |
01-01-2009, 10:21 PM | #5 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
I am running the soft whites up front with the stock blues in the rear with 35wt oil in all for shocks and it seems to work well, but I also have other mods done to my set up such as a double reverse triangulation skid and a few other mods....
01-01-2009, 10:32 PM | #6 |
Pebble Pounder Join Date: Jun 2007 Location: Red Bluff ,California
On my Artr The pivot balls in the rod ends were plastic as well as the nuts holding them in place. I had the same issue..the suspension was way to stiff compared to my friends kit built AX10. I think the plastic ones were compressed from the nuts being overtightend. I Just had to replace the plastic "balls" with some traxxas one i had laying around, or purchase the Axial metal ones. Worked out great! Hope this helps.
01-02-2009, 01:50 PM | #7 | |
Quarry Creeper Join Date: Sep 2008 Location: !! MOAB !!
This happens all to often. Who thought it was good idea to make a ball end out of plastic. | |
03-06-2009, 05:21 PM | #8 | |
Rock Crawler Join Date: Apr 2005 Location: Humble
Thank you, I thought I was going crazy, I had a kit when they first came out and I remembered running preloads up front. I sold it after I built it up into a Trail rig. I just got an ARTR and was like WTF, this suspension is twice as hard as the kit, everyone told me the springs were the same. I just swapped to pede pivot balls, much nicer. | |
