01-16-2009, 06:06 AM | #1 |
Rock Stacker Join Date: Jan 2009 Location: La Paz, Bolivia
| AX10 Upgrades - Give me ideas
Friends: I have an AX10 with a Traxxas 12T55 Motor, HIMOTO 3 Way ESC, and 7.2 V Venom Flat battery packs. My rims have stick on lead strips in them. (About 75 grams in each). Foam is star cut. What is a better Motor+ESC+Battery combination? I recently ordered metal drive shafts since I hear these break. Thanks amigos! Migs |
01-19-2009, 08:59 PM | #2 |
Newbie Join Date: Oct 2008 Location: BFM
MIP centers and Axial cvds! Dig of course!
01-20-2009, 03:40 AM | #3 |
Hi big sky. Can you tell me what each is and if you can suggest which one of each to get? Right now I barely recognize the three terms. Thanks amigo! -Migs |
01-20-2009, 03:55 AM | #4 |
Can dig be set up with a Spektrum DX3R transmitter and a stock AX-10 (with additional parts)? Or will it require more channels? -Migs
01-20-2009, 05:45 AM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
Dig will work with that...he means MIP is that brand name for the center drive shaft. And the CVD's is the name for the type of axle that is used for turning. This helps with more of a turning radius which is key for crawling. You just have to search the vendors to see exactly what you want. I would also upgrade the steering servo. With the added weight of the tires, you're going to want a better servo. Atleast a Hitec 645mg or I think it is the 5645mg servo but don't quote me on that. You might want to even try high clearance links. It is made by a lot of companies but you can just buy the Axial ones. Helps on ground clearance.
01-20-2009, 06:47 AM | #6 |
Hi: I have a HiTec HS-985MG servo for the steering. I'm curious for an aftermarket Dig. I haven't found any yet. I ordered the CVD and some bent links. Migs |
01-20-2009, 10:04 AM | #7 | |
Rock Stacker Join Date: Dec 2008 Location: Calgary-Canada
http://www.rccrawler.com/axialcompbuild.html | |
01-20-2009, 11:09 AM | #8 |
Pebble Pounder Join Date: Jan 2009 Location: Crestview
i am using Novak's Rooster Combo. it has the ESC and 55T motor. works good. as far as a battery, i am currently using a 3000mah NIMH 6 cell pack. after i bought it, i decided to split it and run on the front axle. the extra weight has pretty much stopped the torque twist and the extra weight helps alot. before anybody asks, yes i took the split battery mounts off and it is just strapped arong the servo. plenty of steering room. |
01-20-2009, 07:52 PM | #9 |
Newbie Join Date: Dec 2007 Location: Hanford
| upgrades
get 30deg links and skid plate or cut yours and relocate your lower links inside chassis. Get rid of stick pack and go with lipo or saddle pack batt and put it on front axle to get better center of gravity. Also relocate reciver and esc to upper links with pieces of lexan or plastic. New tires is a must. That is just a few. Here is a couple of pics of mine for options. |
01-21-2009, 04:21 AM | #10 |
What frame are you using in the pictures? Did you tint the clear Lexan panels or were they that way? -Migs
01-21-2009, 01:20 PM | #11 |
| chassis and body panels
Migs the chassis is a TCS Edge and the body panels are just simply a 2 Liter Sprite bottle. The Edge chassis is half price right now on TCS.com. I used all my existing hardware on the truck then did the full droop on the suspension. Just let me know if you have any more questions?
01-21-2009, 02:08 PM | #12 |
It looks really cool! I like the Sprite plastic panel idea. It would have not occurred to me and is simply a brilliant way to save some money! I like your chassis a lot more than the stock AX-10 body. Is it harder to work on since it isn't removable?
01-21-2009, 04:41 PM | #13 |
Newbie Join Date: Dec 2008 Location: Ipswich, QLD, Australia
01-22-2009, 12:33 AM | #14 |
Newbie Join Date: Jan 2008 Location: Lemoore
Nice rig DDR! Migs, don't let the big name brands for parts make ya thinks they are your only option. If you see stuff you can fabricate on your own, do it. You may come up with something cooler and more durable than the next guy. Lots of hardware can be found at places like ACE and NAPA, places that have good selections in "pic your own fastener" isles. Some other tips I can along with DDR is your articulation. Alot is cool, but too much is useless. The goal is to have the lowest center of gravity, highest ground clearance, and the best controliblity. And balancing all these factors is the fun of the sport. Figuring out what works and what don't. If you have your own pile of rocks and you can make over it, your pile of rocks is not difficult enough yet Good luck, and I want to see pictures! |
01-22-2009, 02:15 AM | #15 |
ditto on what skinkrawler said he is the one who actually brought up the sprite bottle I was just going to use a clear coke bottle but I am glad I went with some stile.
01-22-2009, 05:53 AM | #16 |
You are right Skincrawler. I have been getting into this sport quickly, and now I have to stop and get the fundamentals down. Fortunately I enjoy the fabricating and tweaking probably more than the driving. Still, I bought some more aftermarket parts, and will tweak and tweak. That's I guess what it's all about. Thanks for your ideas! -Migs
01-22-2009, 09:02 AM | #17 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
Integy 55t motor $25.00 Tekin FXR esc $100.00 3 cell lipo $35.00 Look into the Tekin FXR it is awesome. I think there is also a Tekin motor/esc combo pak. Holmes Hobbies is a good place to look for lipos. Give him a call he is very helpful and has great customer service. |
01-23-2009, 11:35 AM | #18 | |
01-23-2009, 12:19 PM | #19 |
Quarry Creeper Join Date: Jun 2008 Location: Phoenix
Upgrade that motor to a 45t or 55t. That is super cheap and easy to do.
01-23-2009, 01:05 PM | #20 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
Novak Rooster ESC 55Tmotor combo is my choice.
