07-06-2009, 12:43 PM | #301 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
I installed the 36/14 OD gears in the front, with HD gears in the rear. The truck performs like night and day and some turns are doable with out the dig more now then before. Also verting is more forgivible, i'm making lines now that I could not before. |
07-06-2009, 12:57 PM | #302 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
hmmmmmmmm whadda you dudes w/ these think, I was just gonna overdrive the front, and leave the ass axel alone...... will i GAIN much performance if i under drive the rear as well? |
07-19-2009, 11:13 AM | #303 |
Newbie Join Date: Jun 2009 Location: Mcgregor
| 43/13 gears
hey guys i just put the 43/13 in the front and the rear axle and iam running r2d tranny with 10 tooth pinion man this thing will pull.but broke the front diff lockup {stock} ordered the iron cross looking diff locks and aluminum diff housings.i will let you guys know if it holds up.i hope so cause i like this set up. Thx |
06-20-2011, 01:31 AM | #304 |
Newbie Join Date: Mar 2011 Location: wisconsin rapids
i was wondering if i could get a different ring set for my ax10.i usualy run a creeper and it has an axial front end on it and it always seemed to engage at a different time when i hit the throttle.i thought it was just cuz the dog bones were "looser" then the cvds in the rear.....now i know why,i think
06-20-2011, 09:16 AM | #305 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
Axial when is the OD gear going to be back in stock???
04-18-2012, 06:10 PM | #306 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
| Re: Optional Ratio Gear Sets
we still want these ya know... people who still have sets can make a killing right now because itsa been soooo long since we have seen them anywhere |
04-18-2012, 06:27 PM | #307 |
Rock Crawler Join Date: Mar 2011 Location: hampton
the 36/14 is the OD gear set? this speeds up the front wheels to help hold the front down right?
04-18-2012, 06:45 PM | #308 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
It overdrives the front axle shafts allowing you to pull the front end up over obstacles easier. The Underdrive is advertised as "reducing" torque twist. you can use both for optimal performance for a comp crawler.
04-18-2012, 06:52 PM | #309 |
underdrive just the rear right? thats the 43/13 set?
04-18-2012, 07:28 PM | #310 |
yes under drive is rear only.
04-18-2012, 07:53 PM | #311 |
thanks man
11-12-2016, 10:49 PM | #312 |
Rock Crawler Join Date: May 2008 Location: in a small town
So never dealing with changing gears before and seeing some rigs for sale with ud/od gears in both axles I just ordered both. So my question is am I not supposed to run both? Sent from my SM-S902L using Tapatalk |
11-12-2016, 11:32 PM | #313 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
Yes. Run OD in the front - 36/14, and UD in the rear - 43/13. Without going through the last several pages of this thread, it provides the rig with a faster spinning front, and slower spinning rear. This help with push, and is what almost all sportys are running because it helps steering without requiring a dig unit. Unless you are running high speeds, which is anything over crawling speeds, run this combination. Some people will tell you that they have had problems with this setup, but unfortunately they messed something else up, or are complete idiots. I've only managed to trash this setup when I tried to do so, with 3S on a 4800KV motor. Crawling speeds are totally safe, and completely advisable. |
11-12-2016, 11:34 PM | #314 |
Thanks Sent from my SM-S902L using Tapatalk |
11-12-2016, 11:54 PM | #315 |
Overdrive front gears help pull the front around but they are weaker than stock ratio HD or underdrive. After chewing up 2 sets of overdrive gears I've gone to running HD stock ratio front with underdrive rear. The gearing offset helps with steering but not as much as OD/UD. But the gears live through my stupid human tricks without fail. |
11-13-2016, 12:58 AM | #316 | |
| Re: Optional Ratio Gear Sets Quote:
