01-20-2009, 10:47 AM | #81 |
I wanna be Dave Join Date: May 2006 Location: akron
done thanks
01-20-2009, 10:47 AM | #82 | ||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I had both gear sets installed for the Nevada State Championships, but the ratios were too different, and it hurt me in a few situations. | ||
01-20-2009, 12:01 PM | #83 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
I like the slightly different ratios f&r though. But what do I know. I am just a dumb rc'r. Never did own one of them there big trucks before. | |
01-20-2009, 12:03 PM | #84 |
Pebble Pounder Join Date: Dec 2004 Location: Acton
Me and my partner jimmy rigged a few gear sets from other cars awhile ago but they didn't last long but worked great. Now they are finally available. I will be ordering a set for all 3 of my axiall axled rigs.
01-20-2009, 02:24 PM | #85 | ||
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
Link geometry Tire compound CG Digs Akerman angle Tire contact patch Axle gearing Tranny gearing I could be way off base but I can't think of much that doesn't translate over. Physics is physics big or small. Moving the torque into the axles with a lower gear set will reduce torque twist. And that's why it's hella rad that axial came out with these. Even lower gears will let you run bigger tires without feeling the increase in torque twist. Argue that with God not me, I didn't make the rules. | ||
01-20-2009, 02:39 PM | #86 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
Hey Miller. The funny thing is Brad is running stock gears out back and the higher setup up front. He did not go bigger with the pinion. So basiclly he has just transfered the toque some. But yet leaving the stock set out back and putting the higher set up front HAS eliminated his torque twist. |
01-20-2009, 02:47 PM | #87 |
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
| What's the tooth count on the gears (pinion/spur) you're running?
01-20-2009, 02:48 PM | #88 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
01-20-2009, 02:50 PM | #89 |
01-20-2009, 03:12 PM | #90 | |
01-20-2009, 03:29 PM | #91 |
01-20-2009, 05:06 PM | #92 | |
Rock Crawler Join Date: Sep 2007 Location: Colorado Springs
01-21-2009, 01:18 AM | #93 | |
Front pushing down? That's a good thing right? | |
01-21-2009, 01:22 AM | #94 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I just look at like clod stall, it helps climb by the front traveling at a faster rate right?
01-21-2009, 09:07 AM | #95 | ||
Correct, only the rear axle doesn't lag for more then a split second unlike clod/berg stall can in some situations. | ||
01-21-2009, 10:48 AM | #96 |
Quarry Creeper Join Date: Apr 2008 Location: Carson City
So Brad you are running the 36/14 up front. correct
01-21-2009, 10:51 AM | #97 |
01-21-2009, 11:01 AM | #98 |
Quarry Creeper Join Date: Jul 2008 Location: SACRAMENTO
So I guess my rig that has almost no torque twist could still work a little better by putting lower gear set in rear? And what is stock ratio ax-10 come with?
01-21-2009, 11:18 AM | #99 |
01-21-2009, 06:00 PM | #100 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
Great news, now i can change out the HPI set in the front with the real stuff.
