Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Will This Work??
Old 01-21-2009, 05:20 PM   #1
Default Will This Work??
Stock AX-10 ESC with a Integy 65t or 55t motor? I heard the stock AX-10 esc is only compatiable with motors around 27t? I'm trying to put together parts to build a custom crawler. I have a locked pede tranny so far. And in the proccess of drawing up a custom chasis to be cut out by the water jet.
jwc123 is offline   Reply With Quote
Old 01-21-2009, 05:52 PM   #2
Simple question to the experienced people...... Nobody know?
Old 01-21-2009, 05:55 PM   #3
I believe ESC's only have a lower limit for motors. So going to a higher turn always works.
Unknown303 is offline   Reply With Quote
Old 01-21-2009, 06:10 PM   #4
i run a 55t on my stock ax10 esc for now. it is not an ideal esc for crawling but will get you moving
milcrawl is offline   Reply With Quote
Old 01-21-2009, 06:31 PM   #5
Ok yea i figured it wouldn't be the greatest, just as long as it work. Now with a ESC do you have to have some kind of progammer for it. Or do i just get the ESC and hook it up to the motor and servo and its good?
Old 01-21-2009, 06:34 PM   #6
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Just hook it up and crawl
Harley is online now   Reply With Quote
Old 01-21-2009, 06:42 PM   #7
Ok thanks. With the controller i have a Nyline controller that works fine. Can i just match the freq. and used it?
Old 01-21-2009, 07:31 PM   #8
Your stock Axial ESC will work fine with a 55/65t motor. The issue with the stock Axial ESC is that is has NO drag brake.....
I hooked up a 55t Axial motor to my stock ESC and it worked great. Half the speed of a 27t motor and a tad more sensitivity.
After swapping the ESC with a Rooster, I had a drag brake and 3x the sensitivity and it was just a better all around crawler.
GrumpyLumpy is offline   Reply With Quote
Old 01-21-2009, 07:42 PM   #9
i use to run the stock esc w/ a novak 55 w/ no problems
you may want to look into getting an esc w/ a drag break though
NeXt559 is offline   Reply With Quote
Old 01-21-2009, 07:44 PM   #10
If I was going to go to all the trouble to have a custom chassis cut I would not go with the bottom of the barrel esc. Get a Mamba, Tekin,Rooster. Instant reverse and drag brake.
One-eyed Jack is offline   Reply With Quote
Old 01-21-2009, 08:06 PM   #11
Its no trouble i have access to lathes, CNC mills, water jets, and all the works anytime. Just have a low budget right now because i back in college. In school for machining
Old 01-29-2009, 08:45 AM   #12
Default Motor
Will a 50mm long motor, from motors mounting plate to the rear of motor, fit in a stock AX10 ?
Thanks
Firefox
Firefox is offline   Reply With Quote
Old 01-29-2009, 02:15 PM   #13
Originally Posted by kdizzle122 View Post
ya it shud work just fine wit no problem my cuzin did that for awhile actually still is usin that
Does your cuzin have to worry much about gators gettin his truck ?
You talkin about the motor question I guess.
Thanks muchly
Firefox
Old 02-06-2009, 05:45 PM   #14
i run a 65t with the stock axial esc and it works fine.
Tyler Kadlec is offline   Reply With Quote
Old 02-06-2009, 05:54 PM   #15
the only limit to the stock ax10 ecs is down to 15 turns , any thing higher will work
BEN214 is offline   Reply With Quote
Old 02-06-2009, 06:27 PM   #16
I joined the Band!
agreed..I have been running an integy 85 turn, 26 tooth pinion.... runs great
MEDiC is offline   Reply With Quote
Old 02-06-2009, 06:57 PM   #17
you can run 27T and higher Less T more amps
rockdevil is offline   Reply With Quote
