Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: TCS Delrin Boomerang Upper Link Mount for Axial AX-10 Scorpion
Old 01-24-2009, 07:25 PM   #1
Question TCS Delrin Boomerang Upper Link Mount for Axial AX-10 Scorpion
do the TCS Delrin Boomerang Upper Link Mounts for Axial AX-10 Scorpion actually help the truck articulate more than a stock y link mount?
blue bronco is offline   Reply With Quote
Old 01-24-2009, 07:30 PM   #2
it does but it helps fight tourge twist more then anything
dirtydirtysouf is offline   Reply With Quote
Old 01-24-2009, 08:15 PM   #3
This is not the point of the 4 link. It will probably actually have a little less articulation which will make the truck more predictable. It will make your torque twist much more managable.
It's one easy cheap mod that works awesome!
mockknight is offline   Reply With Quote
