Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Hot Racing DIG Parts ?
Old 01-25-2009, 08:04 AM   #1
Default Hot Racing DIG Parts ?
Wanting a dig, thinking about the hot racing unit.
My question is has any one had to replace parts in them yet if so hows the availability of parts and service for this unit.
Also any one had a problem with " roll back " with this unit.
Bent axial is offline   Reply With Quote
Old 01-25-2009, 08:38 AM   #2
Hobby etc, nashua NH....Hot Racing dealer. dig $44
Rocksolo is offline   Reply With Quote
Old 01-25-2009, 12:21 PM   #3
I just put one of these on last week, I have around 12 to 15 hrs. on it . Not a bad dig for the money. It was bought from tcs crawlers for around $48 shipped. The only problem was with getting the linkage set right. But overall IMO not bad.
bcbaja is offline   Reply With Quote
Old 01-26-2009, 07:50 AM   #4
any one else need parts or now where to find them.
Old 01-26-2009, 08:18 AM   #5
I have about 12 packs thru my truck since I added the HR dig. I have had no problems yet. the unit is very sturdily built. brass bushing and hardened steel tranny output.(no aluminum to wear out). You dont have to mount your servo up above the motor and tranny; I mounted mine behind the motor. I used an old losi servo I had in my beat but not dead parts bin. I will upgrade to a micro later to lower my cog, but not till the losi one dies.
The key I think to smooth operation is good grease, and as level and straight a dig linkage as possible. Mine digs flawlessly even under a moderate amount of load. My only problem is once I cover the linkage with the body... Im screwed but with the body off where i can see the linkage it works great!
When mine wears out and I need parts (if it does it maybe a while by the looks of it so far) for $44 I'd probably just buy another one
Old 01-26-2009, 08:24 AM   #6
I was also thinking about getting this dig could we see some pictures?
rider12693 is offline   Reply With Quote
Old 01-26-2009, 11:29 AM   #7
heres some pics of mine in a slingshot
hodges996 is offline   Reply With Quote
Old 01-26-2009, 12:56 PM   #8
I have had my HR dig in for about 20-25 11.1v lipos thru mine and it doesnt miss a shift even under load. I take mine apart once a week to check for signs of ware, and none yet. My DNA wore the alum. cog right down twice after about 4-5 packs. IMHO the HR is the way to go, and for $45 i would buy another one. The DNA rebuild kits are $30 a pop and they ware out quickly. Just my .02
bigskycrawlin is offline   Reply With Quote
Old 01-26-2009, 02:09 PM   #9
Hodges, that's pretty trick the way you have the dig servo mounted.
P1choco is offline   Reply With Quote
Old 01-26-2009, 02:47 PM   #10
its 4XADICT's design. but thanks anyway
Old 01-26-2009, 05:42 PM   #11
spend the extra 20 or 30 and get a dna dig. i have not had good luck with hot racing parts and i emailed them many times with issues and they have never returned 1. i will not buy hot racing products ever again. buy a product that people stand behind. DNA dig,TCS dig or the CKRC dig before you buy the hr . you will not find replacement parts for it.
BILLYGOAT is offline   Reply With Quote
Old 01-26-2009, 07:03 PM   #12
you dont replacement parts when u could buy a whole new one (if needed) for less than the price of the dna rebuild kit
Old 01-26-2009, 07:05 PM   #13
everyone has an opinion . that is just mine .
Old 01-28-2009, 06:59 PM   #14
Default dig servo mount
I used cheap sheet aluminum but I think I
l'l be using hodges idea with the rods...real cool
