Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: droop setup on stock ax10 shocks
Old 01-25-2009, 08:07 AM   #1
Exclamation droop setup on stock ax10 shocks
anyone know if I can go to droop route on the stock ax10 shocks without use any internal or external spring only fuel tubing and shock oils ?
AlphaDOG is offline   Reply With Quote
Old 01-25-2009, 09:03 AM   #2
TEAM MODERATOR
EeePee's Avatar
Droop set ups need the internal spring or they won't work their best.
With nothing to suck the shock back closed, the truck can do whatever it wants, and not in a good way.
EeePee is online now   Reply With Quote
Old 01-25-2009, 10:25 AM   #3
before adding internal-springs...my suspension would always unload, causing me to fall backwards when attempting to do simple climbs like this one:
http://www.youtube.com/watch?v=0rmbgcph4ys
mr_manny is offline   Reply With Quote
Old 01-25-2009, 10:53 AM   #4
Yeah, you need springs and thick oil. If you don't use the internal springs from TCS try your local hardware store. I took a shock body in with me and bought 4 of every spring that would fit. They only had rate info on a few of them so I found a spring rate calculator online to get an idea of what I was working with. I ended up using three with about 4lbs/in and one with about 9.lbs/in. The stiffer one went in the right rear to keep it from unloading on me. I experimented with a lot of different oils (from 50wt to 3000wt). I found a happy place with a 50/50 mix of 1000wt and 3000wt to give me approx. 1725wt. (another useful calculator online). My next step is choosing which aftermarket shocks to use.
chops1sc is offline   Reply With Quote
Old 01-25-2009, 01:49 PM   #5
Ditto on needing the internal springs. I tried a droop on my Fatdog tuber I built last year without springs, and it sucked.
FFCrawler is offline   Reply With Quote
Old 01-25-2009, 04:10 PM   #6
ok good!
anyone got a link for good spring from greathobbies or towerhobbies ?
Old 01-25-2009, 06:52 PM   #7
checkout your local hardware store.
you will be surprised how many springs in various rates they carry.
cheap too
use your diagonal cutters if you find some that are too long/or to tune them to your rig.
Old 01-25-2009, 07:20 PM   #8
tjb
TCS has them in different weights also.
If you are going to use the shocks in droop, get the STRC aluminum bodies for them also (come in a set of 4). They help keep the stock caps from popping off......
tjb is offline   Reply With Quote
Old 01-28-2009, 07:37 AM   #9
Hi guys...
Yesterday i mounted a pair of new alluminium shocks on my axial ax 10 ckrc stage 2... now when the crawler is at rest it is very very low, with very few ground clearance. Moreover, when shocks are compressed the drive shafts strikes the alluminium "Y".
How can I resolve this problem?
Perhaps removing the spacer that there's between the Y and the axle?
Hendel is offline   Reply With Quote
Old 01-28-2009, 07:49 AM   #10
That picture looks like it still has the stock shocks on it?
syber70 is offline   Reply With Quote
Old 01-28-2009, 08:05 AM   #11
Now i've the alluminium shocks in droop configuration, i took the photo from here (is the tutorial i've followed): http://www.rccrawler.com/axialcompbuild.html
Old 01-28-2009, 10:50 AM   #12
flapjack's Avatar
Smile
i used pen springs 35 wt oil and double bias valved the shocks ( 2 hole on top as stock in a artr scorpion took the rubbers out and put a single hole dampening plate under neath the stock one between the spring and orig plate) seems to help with torque twist also used soft race springs from losi on the outside and mounted them upside down to avoid popping the shock tops off ...fyi the tops of my shocks are mounted just above the upper link mounts making it "catepillar" when trying to high center results in a low ride height sytem that articulates over 180 degrees with out popping parts ..... it works for me but it does drive alot diff then other peoples rigs
flapjack is offline   Reply With Quote
Old 01-28-2009, 11:01 AM   #13
4 linkthe rear i had problems at full flex the driveshaft would hit my electronics plate but i 4 linked the rear and that fixed the issue
nylintmaxx is offline   Reply With Quote
Old 02-06-2009, 02:16 AM   #14
which side of the shock does the spring go in; before, on the rod or after the plunger? sorry not the mis-nomiclature.
minor_threat is offline   Reply With Quote
Old 02-06-2009, 02:26 AM   #15
Under the piston.
2JSC is offline   Reply With Quote
Old 02-06-2009, 02:39 AM   #16
right on. didn't some one post a drawing of droop and the other version of internal spring'd shocks? maybe the newcastle's thinkin' but i thought i saw it here.
Old 02-06-2009, 02:46 AM   #17
Yah, its around somewhere. Droop would place the spring under the shock. If you want a convensional sprung shock, you can put a small spring inside and on top of the piston.
Old 02-06-2009, 02:52 AM   #18
so i've sprung my droop by getting it all ack backwards. bummer. thnx for the clearification though.
why would anyone want sprung? wouldn't that be similar to external coil spings?
oh, misfits fans, Posts: 138 LOL...okay, i'm outa here.
Old 02-06-2009, 06:49 AM   #19
Okay but if the entire shock was inverted the spring would the go on bottom of the diaphram. Right? The spring should always go on the bottom of the shock body, if it is mount normal or inverted. Right?
Jason
JaynDrea is offline   Reply With Quote
Old 02-06-2009, 06:51 AM   #20
Default pens
you can use the springs from ink pens for the internal shock springs
intheworks is offline   Reply With Quote
