| | #1 |
| Newbie Join Date: Apr 2008 Location: Turn Aroind...
| I just got my first crawler a week ago (AX-10 ARTR) and I was looking at TCS and I saw some internal springs and I was wondering if you still use oil with internal springs? |
| Sponsored Links | |
| | #2 |
| Is this real life ? ![]() Join Date: Oct 2008 Location: Alpine,CA
| Yes |
| | #3 |
| Quarry Creeper Join Date: Aug 2007 Location: Amarillo, TX
| Yes, I used 30wt on all 3 with the left rear being 45wt w/ medium tcs springs... (This being used on my old edge chassis) |
| | #4 |
| Ok, thanks. |
| | #5 |
| Quarry Creeper Join Date: Sep 2008 Location: !! MOAB !!
| I am currently running the medium internal springs and 45wt oil. I think that something like 60-70wt would work a little better, but that is just my 2 cents. |
| | #6 |
| Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
| If you want to save some money go to the local ace hardware or whatever and snoop arround a bit. I found like 5 or 6 diffrent spring that either fit perfectly on the sock shaft or around the body and are all diffrent strengths. I even going one step farther and doing a progressive setup and putting in a longer shaft spring and a shorter body spring for more tunability. |
| | #7 |
| TN State Champ 2011 ![]() Join Date: Oct 2008 Location: Chattanooga
| I've never really understood the intetnal spring thing. Are you running these in a droop set-up exclusively or good for sprung applications also? What is the benefit over non-internally sprung methods? Are you still limiting your shocks internally? |
| | #8 |
| Pebble Pounder Join Date: Feb 2008 Location: on the edge of sanity
| you can still run limiters on your shocks, ive found that use of internal shock is more for clearence issues in a standerd non droop setup unless your running a droop setup, than internal is a must,and also gives a sleek look too,lol,, like that matters, as far as oil, for example, without oil if your front tires spin on a rock they tend to bounce or decending of a ledge and landing hard, the use of oil tends to stop the bounce, also as it articulate, makes for a more smooth transition, less jerky, bouncy, or whatever you want to call it, makes for more control and i think it makes your rig more predictable, its always better to know what your rig is going to do or how it will react in a certain situation,,,,as for benifit, it will be different for each his own, different style driving- diffenent setup just my .02 cents Last edited by lizard017; 01-27-2009 at 11:25 AM. |
| | #9 |
| Newbie Join Date: Dec 2008 Location: Issaquah, WA
| what is the advantage of doing internal springs vs external Thanx a bunch |
| | #10 |
| Made the switch to 70wt and it perfoms like never before. I love having a super stable droop setup now. |
| | #11 |
| Rock Stacker Join Date: Jan 2009 Location: OZ
| | #12 |
| Yes both front and rear. I do have a 1/4 inch of fuel tube in the front right to help preload the spring a little. I found that only going up realy steep (63 + degrees) I was getting a small amount of torque twist. In a droop setup you need to remember that it is opposite of a conventional sprung shock. (outer sprung rigs preload the left rear, Droop you preload the right front IF you need to. Hope this helps. |
| | #13 | |
| Thread Tools | |
| Display Modes | |
