Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Ax10 snow winter setup
Old 01-26-2009, 05:13 PM   #1
Exclamation Ax10 snow winter setup
AXIAL AX10 STOCK CHASSIS WITH CHEVY BLAZER K5 BODY.
FRONT AND REAR DIFF LOCKED.
INTEGY 65T MOTOR.
14T PINION.
87T SPUR GEAR.
8 CELL SADDLE BATTERY PACK @ 9.6V.
PROLINE M3 BADLAND ON FRONT WITH STOCK FOAM NO TRIMMED NO WEIGHT AND CUSTOM MADE CHAINS ADDED.
PROLINE MASHERS 2000 M3 ON REAR DOUBLE MODS TIRES/WHEELS FOR MORE POWER/TRACTION AND FLIPPED THE MASHERS TIRES BACKWARD TRIMMED FOAM ON 2 FIRST TIRES AND STOCK FOAM ON THE 2ND ONES NO WEIGHT.
LET ME KNOW WHAT YA THINK!
AlphaDOG is offline   Reply With Quote
Old 01-26-2009, 05:17 PM   #2
Looks pretty mean... but does it crawl? Post some action pics!
MtnBkr is offline   Reply With Quote
Old 01-26-2009, 05:18 PM   #3
Cool! I guess those tire chains bite really well in the snow!
dR. hOOK is offline   Reply With Quote
Old 01-26-2009, 05:22 PM   #4
I dont really crawl im more into trail fun
Old 01-26-2009, 05:42 PM   #5
Have you tried any kind of lube to keep the tires from loading up?
tanmonster is offline   Reply With Quote
Old 01-26-2009, 05:47 PM   #6
lube for loading of snow ?
Old 01-26-2009, 06:14 PM   #7
What esc are using in the snow?
moabax is offline   Reply With Quote
Old 01-26-2009, 06:41 PM   #8
You should get a different spare tire, those Slash tires don't work well in the snow. j/k
I really like the truck.
wbillylee03 is offline   Reply With Quote
Old 01-26-2009, 06:57 PM   #9
I just put my winters on. I have the masher 2000's with no weight all the way around and similar custom tire chains on all 4 corners too. I went with an old lexan power wagon lid to keep the weight down in the snow. The first couple storm were great for crawling and trail riding (in the snowshoe tracks around the yard. And those snowbanks the plow leaves behind...wow do you get some technical crawling runs from them.
Nice rig,
M
m00nst0ne69 is offline   Reply With Quote
Old 01-26-2009, 10:53 PM   #10
how did you mount the rear tires?
merrillon24s is offline   Reply With Quote
Old 01-27-2009, 03:22 PM   #11
sorry guys no action vids
it work fine but anyways chains or better tire or not when you dig into soft snow you will be owned by anyways you are setup
Old 01-27-2009, 04:01 PM   #12
id love to see how you did your duals on back
any broken down pics
lizard017 is offline   Reply With Quote
Old 01-27-2009, 04:19 PM   #13
I would be interested to see how the duals were done too. I have been thingking about that for a while. I don't think it would crawl to well but it sure looks cool.
torque monkey is offline   Reply With Quote
Old 01-28-2009, 01:16 PM   #14
heh so simple I used only 2 tie wrap aka zip tie to put them together..
Old 01-28-2009, 01:18 PM   #15
post pictures and infos of your winter setup ride guys
Old 01-28-2009, 01:56 PM   #16
My ries always load up on snow when I drive in the white stuff. I was wondering if anyone had tried any kind of oil or compund that would reduce the snow's ability to stick in the tire treads.
Old 01-28-2009, 02:08 PM   #17
Here is my xtrail bronco in the snow. I waterproofed everything with plastidip and dielectric grease. I have a set of chains for this but in the fluffy stuff they dont work as well.
Old 01-28-2009, 08:10 PM   #18
i find the best thing for snow is lightweight and gobs of power
header is offline   Reply With Quote
