Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: ax-10 comp build
Old 01-26-2009, 11:02 PM   #1
Default ax-10 comp build
I got this rig off my friend and it sat for 6 months now i decided to have a go at a comp crawler. For components i am running the following.
hitec 5645mg @6volts for steering
hitec 645mg @6 volts for dig
rc4wd r2d tranny
holmes hobbies crawlmaster brushless outrunner
castlecreations mamba max esc
castlecreations bec
rcp max clearance knuckles
axial cvd front axles
axial black alum hub
rcp alum link plate in rear
strc center skid custom machined for r2d
strc front servo/batt/link mount plate
mip cvd driveshafts
hot bodies rover tires white compound custom foam
axial beadlocks
hobby people threaded alum 4" shocks
strc alum three link mounts
1200mah 11.1v lipo
futaba t7c radio
I will post pics soon
TWISTEDBYDESIGN is offline   Reply With Quote
Old 01-26-2009, 11:03 PM   #2
Black letters not good, could you use a different color please?
axman2010 is offline   Reply With Quote
Old 01-26-2009, 11:52 PM   #3
is that better i like the black but if it is still to hard to read i will change to white.
Old 01-26-2009, 11:57 PM   #4
Oh you stepped up and got some MIP driveshafts...NICE !!
That was some nutty stuff when you popped a rear then front within 5 seconds !!
Better get those rovers dialed
Now get some pictures up !!
hessian18 is offline   Reply With Quote
Old 01-27-2009, 12:03 AM   #5
Yup its good, thanks. Also nice parts list, now get some pics up!
Old 01-27-2009, 12:14 AM   #6
Nice parts list post up some photos let us see details sounds sweet
Timothy Hill is offline   Reply With Quote
Old 01-27-2009, 12:20 AM   #7
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 01-27-2009, 12:21 AM   #8
thanks for the help on the pics bob
Old 01-27-2009, 12:33 AM   #9
No problem...
Here is another tip..
After each [IMG] URL hit enter and start on a new line...
Like this...
http://i231.photobucket.com/albums/e...ke6844/035.jpg
http://i231.photobucket.com/albums/e...ke6844/032.jpg
http://i231.photobucket.com/albums/e...ke6844/037.jpg
http://i231.photobucket.com/albums/e...ke6844/038.jpg
Old 01-27-2009, 01:35 AM   #10
here is a photo of my trans installed. I removed the clear cover on the r2d and moved dig bracket in closer to trans center of gravity is really low. I also replaced stock hardware that holds dig together i used button head bolts from inside trans and sandwiched the dig to the trans. the reason i did this is the dig fell apart on a trail and caused the trans plate to strip.
Old 01-27-2009, 01:39 AM   #11
also anyone using a holmes crawlmaster with r2d you will have to notch dig to clear motor otherwise it will just scrape can on outrunner sorry john shes brand new and already hammered on
Old 01-27-2009, 01:41 AM   #12
Old 01-27-2009, 01:44 AM   #13
I now have .750 more belly clearance than before just from tires.
Old 01-27-2009, 01:56 AM   #14
this truck worked very well with the losi claws but ever since i received the rovers and crawlmaster it just blows the plastic driveshafts right off so i am going to rcp tomorrow to get mip driveshafts then hopefully it will be back in buisness. and the rovers take me up new lines never before possible. the first time out i had too much foam in them and they were working against me but that issue has since been fixed. the r2d trans is geared really low and since fixing the dig seems to be really reliable. the torque from my motor/trans was allowing my wheel hexes to strip so i got the black ones with little nubs on them and they hold on way better.
Old 01-27-2009, 03:24 AM   #15
thanks alot
Old 01-27-2009, 06:33 AM   #16
nice build...I like your setup.
the3kid is offline   Reply With Quote
Old 01-27-2009, 10:16 AM   #17
looks good love those tires
mac67 is offline   Reply With Quote
Old 01-27-2009, 11:06 AM   #18
thanks guys i will post more pics tonight after i get driveshafts and make some changes
Old 01-27-2009, 11:33 AM   #19
WVB
What was the remedy..?
WVB is offline   Reply With Quote
Old 01-27-2009, 11:53 AM   #20
I like the rovers best. I have been to two comps and placed 7th overall in 1st and won second one
BIGJOEDUCKSLAYE is offline   Reply With Quote
