06-28-2009, 11:55 AM | #221 | |
Quarry Creeper Join Date: Apr 2009 Location: Israel
Would shortening the links achieve the same ? | |
06-28-2009, 02:53 PM | #222 | |
To bend the links I used a heat gun. I did however bolt the links together (via the rod ends) and bent them at the same time to iensure I got an even bend in the two links. You'll know when you've heated it enough because the memory in the delrin will begin to want to straighten out the rod on its own. | |
06-29-2009, 09:57 AM | #223 |
Thanks for the reply. Once the correct heat range is reached the links want to straighten, so I should bend them to my liking and stick them in a vise until they cool off ? will that work? |
06-29-2009, 10:55 AM | #224 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
| If you want to change the bend, hold one end in a vise, heat until it shines, bend to your desired angle, and remove heat source. Hold at your desired bend for 15-20 seconds after removing heat and it will be cool enough to let it go and hold it's new angle.
07-08-2009, 05:52 AM | #225 |
Rock Crawler Join Date: Jan 2008 Location: Cotati
Hey Don, How did you mount your body? I don't see any posts.
07-08-2009, 08:01 AM | #226 |
Quarry Creeper Join Date: Oct 2005 Location: Lebanon
what body is that in the first pics?
07-08-2009, 09:20 AM | #227 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
he is running a very trimmed axial XC-1 body! Last edited by bigflex; 07-08-2009 at 10:49 AM. |
07-08-2009, 09:22 AM | #228 |
07-08-2009, 10:06 AM | #229 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
He'll be running another one too once I finish painting it.
07-08-2009, 10:48 AM | #230 |
07-08-2009, 12:43 PM | #231 |
Quarry Creeper Join Date: Jun 2008 Location: Sykesville MD
Can we get some pix without the lid on it. I am having some issues getting mine to climb like I think it should. Just looking for some Ideas on link placement.
07-08-2009, 01:42 PM | #232 |
07-08-2009, 09:35 PM | #233 |
07-10-2009, 01:15 PM | #234 |
Newbie Join Date: Jun 2009 Location: Toronto
Hey, Don, I've just got my SSS today, what should I use to assemble the links? what kind of ball-ends? and are the white tubes come with the chassis suppose to be cutted by myself in order to fit? |
07-10-2009, 01:19 PM | #235 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
You use the large revo rod ends http://www3.towerhobbies.com/cgi-bin...&I=LXHGB7&P=ML The spacers provided you can do whatever you want. I used them to space out the chassis braces to clear the trans. |
07-10-2009, 02:26 PM | #236 |
hmm, thx, I'll go look for them... and another thing is, are the chassis suppose to bend to fit axle? |
07-10-2009, 03:05 PM | #237 |
Later on tonight in my thread i'll post a little info for the newbs to the SSS to check out. some people have differances of how to set theirs up. but with the help of alot of people here I was able to get it somewhat dialed in. I still have some more building to do but it will help alot with the understanding.
07-10-2009, 09:54 PM | #238 |
