Thread: AX10 Comp Build
Old 03-09-2009, 03:24 PM   #21
glad to see that it's working for ya, just a few minor tweaks and it should be dialed in, see ya on Sat.
sub-zero is offline   Reply With Quote
Old 03-10-2009, 01:09 PM   #22
"HOLLYWOOD"
Mini's Avatar
Gonna have to see if I can make it up there this sat. don't count me out just yet some things came up that I have to take care of.
But yea today am putting the finishing touches on the wireing and the DIG. And then I have to start preping diffrent foam setup's to see what works good, good thing is I really only have to tune the rear tires. with the pink memory foam there were just way too soft so gonna try the stock panther foam with axial lizard sidewalls to see how it works out.
Mini is offline   Reply With Quote
Old 03-11-2009, 08:48 AM   #23
this rig is ugly!!! lmao. good stuff. those stands are badass. lol. btw guys im minis boy. we live in miami and have pretty much identical rigs. we went out sunday but them tires are no joke. were gonna do some foam setups this weekend cuz the rear buckles too easy and the rig locks up. we have the same rims so were just gonna try everything out on his rig to see what works then try it on my rig to see what works cuz our suspension is slightly different. good job mini.
I AM THE STANDS BUILDER. lol
is it sunday yet??
JaDeR is offline   Reply With Quote
Old 03-11-2009, 09:04 AM   #24
"HOLLYWOOD"
Mini's Avatar
You for real is it sunday yet lololol.
Yea guys like my boy said he's the stand builder if you guys have any question feel free to PM me or Him for questions on pricing and things like that since the request was pretty high might start making them.
Old 03-11-2009, 01:42 PM   #25
TN State Champ 11,12,13
Pdog7's Avatar
I love your home made double reverse triangulation skid mod. Way to think outside the box. We will have to refer to that as the mini mod.
Pdog7 is offline   Reply With Quote
Old 03-11-2009, 02:28 PM   #26
"HOLLYWOOD"
Mini's Avatar
lol thanks, yea usually I see only see rear triangulation. And I ordered and extra 2 SWX plates just incase did not work out, I have a regular one the one you see now and only rear triangulation. Gotta be prepared for anything lol.
Old 03-11-2009, 09:50 PM   #27
Originally Posted by gunnar View Post
Not telling you what to do at all, but maybe clock the motor so the wires are on top and run them over the motor to the ESC. I think they will thank you for it, just keep em away from the spur.
I have found this to work for me than it goes right to the chassis to be tied up.
5150bronco is offline   Reply With Quote
Old 03-11-2009, 10:30 PM   #28
"HOLLYWOOD"
Mini's Avatar
Yea thats what I did just finished re-wireing everything and turnning the motor upwards. Also tweaked my DIG I think it's set.
Old 03-11-2009, 10:58 PM   #29
Ex Nor-CalRCRC slave
gunnar's Avatar
Time to post up some vids
gunnar is offline   Reply With Quote
Old 03-11-2009, 11:15 PM   #30
"HOLLYWOOD"
Mini's Avatar
Yea I know got a little brick track setup in the back
Old 03-25-2009, 10:21 PM   #31
"HOLLYWOOD"
Mini's Avatar
UPDATE:
Well finally got some parts I was waiting for from RC4WD and RCP and RPP.
For my comp build had one huge problem every time I would go out to test run, the link's would pop out of the plastic ends so made a little order from RC4WD and got there metal end's straight and curved love them.
Also extened the top of the shocks a bit with bigger spacer's
Swiched the stock losi white shocks to red huge diffrence. Running Losi 42 weight oil also huge diffrence.
Got rid of the bent steering end's and made them straight great turn radius and now the tire's hit befor the steering bar also thanks to the vanquish high steering knuckels. ONly had to mod the servo arm a little to clear the lower bar.
Was running parallel top links but felt was not really feeling it were they were set so got some 6x91 to push the rear up a little more and give my axel more angel also.
Here are some pics of the new hop-ups on the rig.
Old 03-25-2009, 10:28 PM   #32
gunnar's Avatar
Pics not showing up? Didn't post? I want pix! I want pix!
Old 03-25-2009, 11:00 PM   #33
"HOLLYWOOD"
Mini's Avatar
Enjoy sorry gimmie a sec.
Old 03-25-2009, 11:09 PM   #34
"HOLLYWOOD"
Mini's Avatar
Here you go.
Old 03-26-2009, 12:03 AM   #35
gunnar's Avatar
That Novak on-off switch is heavy, better move it under that motor. Lower COG! Nice build Mini.
Old 03-26-2009, 07:09 AM   #36
"HOLLYWOOD"
Mini's Avatar
Thanks brother dude beleave it or not that was one of my big issues is were to mount that lolol. And when I saw the 2 holes on the DIG Trani was like yes perfect and it's out of the way were it can not be damaged .
Oh and as you can see moved the cabel's
Old 03-26-2009, 07:43 AM   #37
How did he make those stands?
MCNorris is offline   Reply With Quote
Old 03-26-2009, 09:43 AM   #38
"HOLLYWOOD"
Mini's Avatar
Made them at my boys shop, he works with kitchen counter tops and he made them. His name is jader do a search for his name he was thinking of making them and selling them.
Old 03-27-2009, 08:27 AM   #39
"HOLLYWOOD"
Mini's Avatar
Should have some little vids up today when I get back home.
Old 05-07-2009, 07:06 PM   #40
"HOLLYWOOD"
Mini's Avatar
Update: Ok did some change in my steering as you can see my knuckles are now alot higher up than befor,
Trying some diffrent springs and also postion on were the spring were located brought the front ones ina little and the rear also.
Lowered my COG just a little under 2.75
So decide to try some diffrent linkage setup also the set-up I had befor did not have enough articulation and chassis was really stiff here are the the reposition of top and lower links.
My next update will have the new axail gearing and novaks tunned rotor.
