04-01-2009, 01:27 AM | #1 |
Rock Stacker Join Date: Jan 2009 Location: simi valley, ca
| Zero ackerman steering for your AX-10
I keep hearing all this talk about how great the new losi 1/10 steers. A big part of why it steers so well is because it has zero ackerman angle built into the steering. For those that don't know what ackerman angle is I will try to explain. Draw a line from the screw that attaches your steering tie rod to the steering arm, through the screw that hold the knuckle to the axle "C", and end that line at the rear axle. If you do that to both sides and the lines are parallel you have zero ackerman. The ideal ackerman angle for a STREET driven vehicle has those lines meet in the middle of the rear axle. With that design the inside tire turns sharper than the outside tire. For some reason the AX-10 was designed with the opposite ackerman angle whish causes the outside tire to turn sharper than the inside tire, this causes to tires to fight each other when turning. The ideal ackerman angle for us is zero. With zero ackerman angle both tires turn at the same angle. Because of this design "flaw" I was not happy my steering and set out to fix it. First I took some measurements and figured out that I needed to move the tire rod screw out .380" on each side to achieve zero ackerman, then I measured the distance between the two holes on the steering arm (.220"). I also had the issue of my servo not having enough throw to steer all the way so I moved the tie rod and drag link toward the knukle pivot apx 1/8" to give me a little more angle. Once I had these measurements I laid them out on some .060 AL sheet, drilled the holes and cut out around them. I needed to use countersunk screws to mount the tabs to the steering arm so I countersunk the top holes before cutting them out. To extend the tie rod and drag link I used a long 3mm screw with the head cut off in place of the stock long set screw with one 1/4 AL spacer and two .065 plastic spacers on each side. I also used one .065 plastic spacer on each post under the servo mount plate to keep the tie rod from hitting the rod end on the servo horn On dry concrete my turning radius only droped from 82" to 73" but on the rocks there is a noticable differance in how sharp the rig turns. I also found one additional benefit to this mod. I run 8 cell saddle packs on TCS axle plates and with the stock setup the rod ends on the left side would hit the battery and prevent full steering to the right. With the new set up the rod ends are further away at full turn and no longer hit the battery. For now my steering angle is only limited by my axles but with CVDs you could replace the front "C" mounting screws with countersunk ones and steer even tighter. FYI all of the spacers I used were from the local hardware store. look for a store with a good selection of Hillman brand hardware. What would be really cool is for one of the aftermarket guys to make AL knuckles with zero ackerman already built in. It would only require a slight design change to the arm off the knuckle. HINT HINT. Last edited by am4x4; 04-01-2009 at 01:51 AM. |
04-01-2009, 03:12 AM | #2 |
That's a pretty cool setup you got going on there I just picked up a set of Egressor's knuckles with arms for both zero ackerman and correct ackerman and I'm loving them.
04-01-2009, 08:59 AM | #3 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
It's great that you fabbed up something to get stock parts to zero ackermann. There are a few companies that produce zero ackermann knuckles, as the King stated. Many crawlers want to increase thier steering angle. You'll find your turning circle reduced alot more than 9 inches on flat ground. It takes alittle moving around of things, and some aftermarket parts, but the result is worth it in the end, just as your efforts have proven. |
04-01-2009, 09:26 AM | #4 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Yea thats why I love my Vanquish High steering knuckels. Plus with gunnars help of remove the angel link ends and putting straight one's I love the fact that I can go head-on to a rock and the tires hit first. Great mod, way to think outside the box, a huge part of this hobbie is thinking outside the box. |
04-01-2009, 09:30 AM | #5 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
Nice setup but this zero ackerman thing is overrated, I'm not dissing your idea - it WILL help with your performance the common misconception of crawlers is that you want zero ackerman. this is not absolutely true. with zero ackerman your tire will still be fighting themselves while turning (because the inside tire has a shorter radius than the outer) Ideally you want both tires to be turning around the same point. IMO, the ideal ackerman angle is -15 deg (meaning the inside tire will turn more than the outside) if you do BTA steering you'll see the banefits of this with stock axial knuckles Last edited by engineerjoe; 04-01-2009 at 09:35 AM. |
04-01-2009, 09:40 AM | #6 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
| The VP knuckles dont change the Ackerman.
04-01-2009, 09:47 AM | #7 |
Quarry Creeper Join Date: Jan 2009 Location: Bay City
| question
Not sure what BTA is? If you could give an explanation and or pictures of your setup I and probably others would apprectiate it. |
04-01-2009, 09:51 AM | #8 | |
On all of my rigs i have stock knuckles (wrong ackerman) and I actually run with quite a bit of toe out to help my turning radius. | |
04-01-2009, 10:42 AM | #9 | |
04-01-2009, 10:52 AM | #10 | |
04-01-2009, 11:47 AM | #11 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
http://www.rccrawler.com/forum/showthread.php?t=163665 pos. or neg. or zero ackermann | |
04-01-2009, 11:59 AM | #12 |
| Those knuckles are CKRC hi-steer units. I don't know if they are zero ackermann or not. I used them to get the tie rod above the pumkin. That is an older photo, things have changed around, and will change again, but the knuckles are still on it.
04-01-2009, 12:44 PM | #13 |
Rock Crawler Join Date: Aug 2008 Location: maple ridge
i just drilled a new hole closer to the knuckle pivot point. works awesome. and no special parts required! |
04-01-2009, 02:26 PM | #14 |
Newbie Join Date: Jan 2008 Location: State College
| A diagram of Ackerman with explanation. Also my 0 degree Ackerman setup with BTA and 45 degrees of steering. |
04-01-2009, 03:06 PM | #15 | |
04-01-2009, 03:17 PM | #16 |
I admit too, I've seen a few funny looking BTA setup's. I think if your going to run a BTA, the simplest servo to tie rod connection is just run a link from the horn to the closest knuckle, as long as there is no interference. The only thing I don't like about BTA is usually the servo has to to be mounted up higher off the axle, where my preference is to run the servo as low as possible. So many things to place there, not enough room, front axles can be tough sometimes. There are clearances in my build that are measured at a hundredth of an inch.
04-01-2009, 03:59 PM | #17 | |
Good post | |
04-01-2009, 05:59 PM | #18 | |
I agree with you on the down side of most BTA setups, It is very hard to get a very low mounted servo with out some really funkey linkage. The setup I am going to try uses straight links with out any clearance issues so far and the servo is not any higher than the stock location, just not lower. As far as Ackerman goes I plan on using a dig when turning tight corners, and want 45/45 not 45/40 degrees of steering, so let the tires scrub! | |
04-01-2009, 09:04 PM | #19 | |
04-01-2009, 09:46 PM | #20 |
He could make up some kind of offset shock mounting, I was toying with that idea, when I just decided to inboard mine instead. He has done some pretty good work so far, if he machined his ring and pinion himself, he's certainly got my attention. Sorry for the slight hijack, am4x4
