Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: stubbs rock rider
Old 04-09-2009, 07:24 PM   #1
Default stubbs rock rider
i just got ahold of a rock rider chassis from NACHO on here .. decided to tear apart my artr crawler and build this .. let me know what improvements i can make as this thing is just thrown together.. i know i need a new 4 link setup as this set up isn't working to good keeps moving on me where attached to axel
stubb is offline   Reply With Quote
Old 04-09-2009, 09:06 PM   #2
pjr
Are the shocks emty right now?(no internal springs)
pjr is offline   Reply With Quote
Old 04-10-2009, 12:43 AM   #3
yea stock shock oil.. no spring
Old 04-10-2009, 01:30 AM   #4
I'd put a spring in there droop style (under the plastic washer so it compresses the shock) and start playing with oil weights. On my ax10 I ransprung in the rear w/ xtm blue Xcellator springs w/ 40 weight oil. And internal springs from the hardware store up front with 1,000 weight shock oil worked great with me crawled awsome.
SCRC is offline   Reply With Quote
Old 04-10-2009, 01:37 AM   #5
Flip the shocks, (inverted) Tmaxx shocks are a good replacement and cheaper than Losi's. Cover the links with Bic pen bodies to help slide over rocks, Add weights to the wheels and think about upgrading the drive shafts. Tubers are generally heavier and will more stress on weak components.
Krakker is offline   Reply With Quote
