Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Glitching issue!!!!!!!
Old 04-11-2009, 04:42 PM   #1
Default Glitching issue!!!!!!!
Guys I've got a AX10 that I just transfered over to a Copperhead Comp Chassis. I used all of the same electronics but for some reason it glitchs really bad and I've done all I know to do... Moved the ESC away From the Reciever, Used the plastic antenna holder to keep wire off of metal chassis.. Can you guys please help me out Im dying to do some crawling.. THANKS
PROBLEM SOLVED!!!!!!!!!!!!!!! F.Y.I Do not let your Antenna wire touch your steel chassis or this is what could happen. Thanks to all those who helped troubleshoot maybe one day I can repay the favor...
WLKNTALL is offline   Reply With Quote
Old 04-11-2009, 04:50 PM   #2
any wires touching the motor?
ultimate_monkey is offline   Reply With Quote
Old 04-11-2009, 04:54 PM   #3
Just moved the wires now its only glitching in reverse this stuff is only 4 days old by the way.....
Old 04-11-2009, 08:35 PM   #4
thats strange
corvette crawle is offline   Reply With Quote
Old 04-11-2009, 08:57 PM   #5
Default Upgrade Electronics!
If you are using the stock Axial electronics (ESC, Motor & Radio). I suggest you upgrade your electronics! I had the same issues and I upgraded to a Novak Rooster Crawler ESC with a Traxxas TQ3 with a Integy 45T motor using the stock 14 tooth pinion gear. Worked GREAT! I still had alittle glitching from the Traxxas TQ3, so I just upgraded to the Spektrum radio DX3S. It will cost you some $$$ for all these upgrades, but your crawler will perform flawless. My crawler works perfectly! Best thing I done to my Axial crawler!!
mbmlcrawlers is offline   Reply With Quote
