| | #1 |
| Newbie Join Date: Nov 2005 Location: Australia
| Does anyone know who sells offset rod ends other than Axial? I need the offset type thats used on the steering of the AX10 (Not the bent type used on the upper links) Axial sells then as part of the AX80005 linkage set, but who makes/ sells them separately? (Plastic, not aluminium) |
| Sponsored Links | |
| | #2 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| Kyosho makes an offset end. Only thing is that they are a bit larger, so they won't fit the stock 3mm grub screws on the links. They thread right on to 6-32 and can be tapped to fit 4mm or 8-32. Size wise...they are about the same as the Revo...maybe just a bit more beefy. Here's what they look like. They are the ones on the axle end of both the uppers and lowers. Here's where you can get them (they are out of stock right now since I already cleaned them out And these are the balls for them: http://http://www.amainhobbies.com/p...oducts_id/3931 Last edited by Offroader5; 04-14-2009 at 09:40 AM. |
| Thread Tools | |
| Display Modes | |
