06-03-2009, 12:18 AM | #21 |
Newbie Join Date: May 2009 Location: Reno, NV
I am running 7oz front, 4.5oz rear.
06-03-2009, 05:46 AM | #22 |
Newbie Join Date: May 2009 Location: Cincinnati
I have stock wheels and tires on my AX10 I have 7.5 oz in the front and about 4 oz in the rear with two 1/8 vent holes in the wheels and I cut triangles into the foam and took sissors and rounded off the edge of the foam. It works great.
06-03-2009, 03:52 PM | #23 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
| I had the blue ax10 with the 72 chevy body on it. I may change the set up but for now I like it. It will climb most anything I point it at. I even made it up that nasty hill at the rox box, on a free crawl day. cant get it to do it during a comp tho. I guess I need more wheel time :-P
06-03-2009, 07:33 PM | #24 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
i am running about 14 oz. total in the front and 10 oz. in the rear total. it is balanced pretty good for hill climbing.
12-31-2009, 04:27 PM | #25 |
Pebble Pounder Join Date: Dec 2009 Location: In the Bluegrass
Quick question? I am going to start with 6oz in each front and 3oz in each rear. Do i need to space the weights out evenly or does it matter?
12-31-2009, 04:31 PM | #26 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
| I try and distribute it evenly by using the holes as guides. I may use 2 pieces, skip a hole, put on 2 pieces, etc. if I don't have wieght wrapped the whole way around. It doesn't have to be perfect, but you don't want it lop-sided!
12-31-2009, 06:27 PM | #27 |
Thanks mascman. I now have the front two finished and they feel really good. I will have to go back tomorrow and pick up another pack of weights for the back.
12-31-2009, 07:02 PM | #28 |
Newbie Join Date: Nov 2009 Location: Placer County
I have 1 full wrap on each wheel. I think it's about 3 1/4 or 3 1/2 oz.
01-01-2010, 11:20 AM | #29 |
Quarry Creeper Join Date: Sep 2008 Location: Oakley
| Same here. I'm right at 14oz front and 10oz rear with tires, foams, wheels, rings and hardware. My crawler seems to do well and no axle breakage.
01-01-2010, 03:00 PM | #30 |
I have all the weights in now and wow what a difference. 12oz total in tront and 6 in the back.
01-01-2010, 05:52 PM | #31 |
Pebble Pounder Join Date: Jan 2008 Location: canada
i just shed half a pound+ in wheel weight, i now run a little over 2ounces in each wheel. before i had heavier in the front now all my wheels weigh the same and i like it |
01-01-2010, 09:41 PM | #32 |
Pebble Pounder Join Date: Dec 2009 Location: roy
does anyone run bb's anymore? Is there an advantage one way or another?
01-01-2010, 10:24 PM | #33 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
BB's help keep the weight low but you can't use them with foams. So I would have to say I don't think many people do that any more.
01-01-2010, 10:39 PM | #34 |
forgot about the foam part still a noob
