Thread: Steering lag...
Old 06-28-2009, 09:34 PM   #1
Default Steering lag...
Howdy folks,
I've been running my AX10 pretty much box stock for almost two years. The truck has work flawlessly until now (except for the drive shafts...went to MIPs problem solved). My rear steer isn't homing like the front. I am using Hitec 5645's on both ends and have noticed that screw going up threw the linkage and "pitman" arm will tilt a little either way when I steer. I put a new screw, rod ends and balls but the problem persists. Any thoughts?
m00nst0ne69 is offline   Reply With Quote
Old 06-29-2009, 12:19 AM   #2
abadk9420's Avatar
It may be time for a new servo, just a thought...
abadk9420 is offline   Reply With Quote
Old 06-29-2009, 07:20 AM   #3
I believe it is less of a problem with the servo and more of a problem with the C hub arm. I think I may be getting some twist there.
Old 06-29-2009, 07:30 AM   #4
Does the screw fit snugly through the rod ends? Is the hole on the knuckle wallowed out? Are these plastic knuckles or aluminum??
JeremyH is offline   Reply With Quote
Old 06-29-2009, 11:09 AM   #5
I will check that out and get back to you.
