| | #1 |
| Rockin' with SMRCRC ![]() Join Date: Mar 2009 Location: In The Dog House
| Okay, before I get flamed, I did try to do a search, and my brain got numb, |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Aug 2007 Location: right above my feet
| yup, the R2d is a different gear ratio, and different pitch, so your pinions that you used on the axial tranny will not work. I found the R2D to be silly slow compared to my axial based rigs with the same motors. (that was a brushless at the time, but dayamn was it frigging slow...) get some pinioins from RC4WD, i would say BIG ones, but that'll depend on your motor and driving preferences. |
| | #3 |
| Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
| R2D is geared very low...they have a gear ratio chart on their site to give you the specs with different pinions. You can only change pinions...no spur gears. What motor are you running? |
| | #4 |
| Gear Ratio Chart: 8 = 30.375 9 = 27.000 10 = 24.300 11 = 22.090 12 = 20.250 13 = 18.692 14 = 17.357 15 = 16.200 16 = 15.188 17 = 14.294 18 = 13.500 19 = 12.789 20 = 12.150 |
| | #5 |
| Thanks guys, I forgot to say that I'm running a Goat system on 7 cells with the 18.5 motor. My tranny came with the following pinions: 8,10,12, and I just opened it up and found it has a 14 in it now. I kinda like not having to have an exterior spur anymore! I was pretty happy with the stock axial gearing thanks to the Goat's high torque and wheel speed, so I'd like to stay fairly close. I will check out rc4wd's site for that chart also. Thanks again! Last edited by papabash; 07-02-2009 at 06:11 PM. |
| | #6 |
| I had a Scorpion HK-2221-12 brushless in mine with 9 tooth, Mamba Max on 8 cells, and it had plenty of wheelspeed, but not enough torque...it would cog / stall. Had good start up, but the motor is just a little too small for comp crawling. Your motor has more torque so I'd try the 10 tooth..could probably use the 8, but might be too much torque. Being brushless, it should have wheelspeed with almost any pinion. |
| Thread Tools | |
| Display Modes | |
