| | #1 |
| Quarry Creeper Join Date: May 2009 Location: brentwood
| Well here is my new VP Chassis, Thanks to the Best LHS around!! Hobbytown USA, Concord Ca, Thanks Mike!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Tanis; 07-03-2009 at 03:12 PM. Reason: fixed pics |
| Sponsored Links | |
| | #2 |
| Chief of Slapaho tribe. ![]() Join Date: Aug 2008 Location: Slapaho, Hawaii
| Those lower shock standoffs are kewl... |
| | #3 |
| any thoughts and Idea's are sure welcome! I can use all the help I can get. I'm still new at this crawling stuff and constructive idea's and suggestions I can really use |
| | #4 |
| Well then.... ![]() Join Date: Feb 2008 Location: NorCal
| Kris - Wow! Sure looks nice in black. I've got to check out your steering link setup next time I see you, that is pretty cool. I've messed and messed with that trying to make something work with all the different offset ends, etc. I like that alot. Very smart. No clearance issues? It's hard to tell but do you get full steering throw with it tucked back? My only suggestion for you is, you might want to switch the fuel tubing out for the axial rubber dampners. Everytime I've run fuel tubing like that, it eventually pushes over the shock end. The Axial ones are thicker and harder. |
| | #5 |
| I will try that, I may have to cut them in half though,looks like it will raise the rig another 1/4", I'm at 2 9/16" now. seems to be these shock set-ups will be the death of me!! |
| | #6 |
| I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| Can you edit your post with a "Enter" in between each picture link..... That will put them all in a vertical line instead spread accross the screen. Rig looks good though. |
| | #7 |
| Quarry Creeper Join Date: Sep 2008 Location: Castro Valley
| I dont think you'll like it. I think you should give it to me for testing |
| | #8 | |
| Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
khwilliams, wanna throw some tech in here so it can stay in this section | |
| | #9 |
| | #10 |
| Latest NorCalRCRC slave ![]() Join Date: Dec 2008 Location: San Mateo, CA.
| Bring that rig to Hobbytown I'll be opening up tonite 7-9, and of course Saturday 10-3. I see a dig servo, but no dig? Ran out of money for the Hurtz Shifter I guess. |
| | #11 | ||
| RCC Addict Join Date: Oct 2008 Location: Lakehood, Crawlerado
For the fuel tubing, just put an extra shock piston (everyone has extras in their kits, or lying around their parts bins) between the tubing and the rod end on the shock shaft. It's small enough to not get in the way of anything, but big enough to prevent the tubing from popping over the rod end. I did it this way because I liked the softer fuel tubing to act more like a hard spring on the end of downtravel. The hard rubber stopper would really act as a limiter only. | ||
| | #12 |
| No, No dig servo yet! Need more Mulla, (DX3R, VP Dig, Dig servo), Thanks Gunner, I'll see if I can get Down There, I Need all the suggestions I can get |
| | #13 |
| | #14 |
| Ok for the Tech, VP Incision Chassis VP 4-link Servo Plate VP High Steer Knuckles R2J Custom 3/8" Bent Delrin Bottom Links, 1/4 Uppers Proline Titus Wheels, HB Rovers Integy HW 50T Novak Rooster Crawler ESC CC BEC CKRC 1500 20c Lipo OD in Front 34/14, stock in rear Robinson 87T Spur Stock Axial ARTR shocks, TCS internal medium springs ahhh......I know there's more...... ahhhhhhh.....Yeaa, those cool a$$ New Shock Mounts from VP Last edited by khwilliams; 07-03-2009 at 04:14 PM. Reason: More stuff to add |
| | #15 | |
| | #16 |
| | #17 |
| | #18 | |
That's a great idea. I've tried washers...but they will push over those as well. A shock piston would be perfect. | |
| | #19 |
| Rock Stacker Join Date: May 2009 Location: lake elsinore
| that thing is sweet man. |
| | #20 |
| Yea , I was a dummy, only looked at the top pic, looked like a spektrum servo, duh, it's the rec. Great build though |
| Thread Tools | |
| Display Modes | |
