| | #1 |
| Quarry Creeper Join Date: Jul 2009 Location: SW Hell
| I have a new AX 10 RTC, bought the Proline Cage,installed it.Heres the problem,When I replugged everything in,my radio is only half working .The throttle trigger is "now the steering "and there is no throttle at all. Is there any pics of the CORRECT way all the electrical and signal plugs should be plugged in,I didnt remember what went where,the plugs on the reciever and motor wires....red motor wire to orange or blue?black motor wire to orange or blue? plus the reciever plugs fit either way....HELP !!!!!!!!:? My very first RC anything.....noob |
| Sponsored Links | |
| | #2 |
| digger ![]() Join Date: Mar 2008 Location: ...in your meter box...
| switch the wires on your reciever. that sounds like the prob. |
| | #3 |
| the plug that comes from my ESC goes in the Batt slot and the one from the steering servo goes in CH2 ,I just dont know which way...or the motor wires ,red to which? orange? blue? |
| | #4 |
| Quarry Creeper ![]() Join Date: Dec 2008 Location: Hawthorne, CA
| Steering servo goes on channel one, esc channel 2. |
| | #5 |
| The lead from the ESC should be plugged into channel 2 and the servo should plug into channel 1. |
| | #6 |
| that is what i meant to say. |
| | #7 |
| didnt work ,does anyone have pix? plus Motor wires? |
| | #8 |
| If you have any pictures of your setup that would help us help you. |
| | #9 |
| The motor wires isnt that big of a deal. You can manualy switch direction if it is going backwards from your transmitter. If the leads are in the right channels, make sure that the ground wire is on the inside. here is a link to axials esc instructions. http://www.axialracing.com/ftp/pdfs/...1_AE-1_ESC.pdf |
| | #10 |
| no cam....sorry |
| | #11 |
| got my Dads....sec |
| | #12 |
| Tomcat18T's diagram should be all you need. |
| | #13 |
| | #14 |
| that help? |
| | #15 |
| Turn it one and try it, tell us what happens. |
| | #16 |
| nothing now... |
| | #17 |
| the Axial PDF is not the same as mine .The Crystal and antenna are in diff places.So I probably smoked it...huh? |
| | #18 |
| If it was smoked it would smell like it... Disconnect everything and connect the servo plug into channel one. Then connect the esc on channel 2. MAKE SURE that the wire colors from the esc the servo plug are parallel to eachother. This matters a lot. If it doesnt work, flip the Servo plug 180 and connect it back in channel 1. Then flip the esc plug 180 and plug it back in channel 2. It should work man. |
| | #19 |
| they are not the same colors,now what? and what is the BATT slot for? the bottom one in my pic. |
| | #20 |
| dont worry about the Batt. slot. At this moment you dont need it. I see you have two reds, one on each so when you plug everything make sure you connect them parallel. I have to take my son to a firework show so when I get back I'll check on your progress. Am pretty sure you can find some help if you search here. It takes time to search but thats what this forum is here for. |
| Thread Tools | |
| Display Modes | |
