Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: broken servo
Old 07-05-2009, 10:43 PM   #1
Default broken servo
hey,
i broke the output gear on my stock RTR ax10.
what actual servo is it?
is it any brand?
can you buy replacement gears?
also, would this be a good upgrade/replacement?
http://www.thetoyz.com/cart/thetoyz_...cat_name=SERVO
or this?
http://cgi.ebay.com.au/Clod-Axial-Cr...3%3A1|294%3A50
thanks.
caljones is offline   Reply With Quote
Old 07-05-2009, 10:57 PM   #2
Go with the hitec in the first link. Don't even waste your time on that stock axial servo.
801FuNk801 is offline   Reply With Quote
Old 07-05-2009, 11:00 PM   #3
the second link isnt the stock one
Old 07-05-2009, 11:04 PM   #4
I know the one in the second link is not the stock one. But you mentioned looking for replacement gears for the stocker. Like I said go with the hitec it's a quality servo that has been proven in many applications.
Old 07-05-2009, 11:09 PM   #5
cool thanks
Old 07-05-2009, 11:19 PM   #6
I would recommend the Hitec 645mg. I've been using one up front for 9 months and its still going strong, that or the next one up in torque.
The second one looks like a generic high torque servo from china that can be found in a lot of electronic supply stores. I have been running a similar one on my rear dig for a few weeks now with no dramas, I was using the original rtr servo for the dig but it wouldnt hold in the neutral position it kept creeping forward.
523revo is offline   Reply With Quote
Old 07-06-2009, 09:52 AM   #7
I joined the Band!
Originally Posted by caljones View Post
hey,
is it any brand?
or this?
thanks.
Typical Axial Electronics. The Futaba S3305 is a good replacement and the servo horn will fit as well. You can find them for $30.00 if you look around. Its a MG HT servo.
grimgard is offline   Reply With Quote
Old 07-06-2009, 10:06 AM   #8
get a metal gear only> traxxas r also gret being waterproof
8upboyz is offline   Reply With Quote
