Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: RTR upgrade alum.
Old 07-05-2009, 11:33 PM   #1
Default RTR upgrade alum.
Hey,
i have an ax10 rtr and i would like to upgrade the links to aluminium.
e.g:
http://rcpcrawlers.com/product.php?p...&cat=29&page=1
with that, it says
Axial AX10 RTR (Ready to Run) owners, this is a very economical way for you to change your kit's plastic suspension links to aluminum links. You will only need 3x14mm set screws, and rod ends + ball links to complete your conversion to aluminum links for your RTR.
20%
could someone please show me where these things are?
or if there is an easier way to upgrade to aluminium?
the main things im after is steering linkages and suspention links, preferable 30* angle
caljones is offline   Reply With Quote
Old 07-06-2009, 12:19 AM   #2
A couple of these:
http://www.tcscrawlers.com/Traxxas-R...2-p-16324.html
is probably what you need. The set screws can also be bought from TCS:
http://www.tcscrawlers.com/TCS-Long-...6-p-16325.html
stianl is offline   Reply With Quote
Old 07-06-2009, 01:08 AM   #3
Hit up R2j, he makes some very nice (and cheap) delrin links, which will slide over rocks much better than aluminum. I think they also come with revo rod ends and 4mm set screws, which is a much stronger setup. I would advise them over aluminum ones any day
Getting to know R2j Kustoms
chrisjlittle is offline   Reply With Quote
Old 07-06-2009, 01:41 AM   #4
abadk9420's Avatar
Here is what you need to convert too Aluminum links on your AX10 RTR/RTC
http://www.rcplanet.com/ProductDetai...IA1411&click=3
It is made by Axial just for that purpose
abadk9420 is offline   Reply With Quote
Old 07-06-2009, 01:46 AM   #5
I would rather buy the Traxxas rods than the stock Axial stuff. The Traxxas rod ends are stronger. But as 'chrisjlittle' writes, Delrin is your absolutely best choice.
Old 07-06-2009, 01:55 AM   #6
no matter what you choose it is a HUGE improvement over those flexy plastic links. I went with the red Axial links and the hardware kit and they were beautiful for the first 20 minutes I had them. After my first test they were all scuffed to hell. Go derlin they will slide better and you dont have to go through the agony of watching your new links get wrecked.
theholybull is offline   Reply With Quote
Old 07-06-2009, 03:37 AM   #7
thankyou all.
ummm
the rtr hardware upgrade kit- http://rcpcrawlers.com/product.php?p...&cat=29&page=1
could someone please explaign it for me?
why do you need all that stuff?
is the rtr a different chassis?
please explaign all this for me
does the kit come with all that stuff?
Old 07-06-2009, 03:48 AM   #8
Devoted axle fan
MadForce's Avatar
The hardware kit includes the set screws, the balls that go in the rod ends, the rod ends and some miscellaneous parts that happen to be on the trees. Not a different chassis but the rtr has plastic one piece links while the kit and artr have alum links plastic rod ends and metal balls. That's the difference. I guess that if you buy the color pack link kit and the hardware kit you have a 55 to 60$ investment while some vendors in here sell complete delrin packages for the same amount or even less. Delrin is WAY better than alum. Search for "delrin+links" in the vendors sector and then contact them for what you need. Vendors in here er very helpfull.
MadForce is offline   Reply With Quote
Old 07-06-2009, 03:59 AM   #9
sorry for the noobiness, but do any vendors do a whole package?
ie delrin links, and all the screws ball ends etc?
thats why i went for the axial stuff, its all in one package.
thanks,
callum
Old 07-06-2009, 07:14 AM   #10
Devoted axle fan
MadForce's Avatar
The best way is to contact them directly cause even if they don't advertise complete links, they might do you a package deal with everything needed to have a drop in set.
Old 07-06-2009, 09:57 AM   #11
I joined the Band!
Go to http://www3.towerhobbies.com/cgi-bin...?&I=LXVEX1&P=Z and you will need this as well http://www3.towerhobbies.com/cgi-bin...?&I=LXVEX5&P=Z
Its the links and the hardware to mount them.
grimgard is offline   Reply With Quote
Old 07-06-2009, 12:35 PM   #12
abadk9420's Avatar
I run the the Real Dogman lower links on my comp rig, he custom makes them for you specific chasis, not sure if he could make you uppers or not but I think he could if you asked him.
http://www.rccrawler.com/forum/showthread.php?t=154925
Old 07-06-2009, 03:26 PM   #13
Buy from Dogman or R2j.
all of you.
there customs make all that shit look like... welll....shit
BEELZEBOB is offline   Reply With Quote
Old 07-06-2009, 04:00 PM   #14
Def go delrin for your links. I just recently switched from Alum to Delrin links and can tell a huge difference in them. I made my own from Delrin rod drilled and tapped with traxxas rod ends. I tappered the ends of the rods to match up to the diameter of the rod ends.
KvilleKrawler is offline   Reply With Quote
Old 07-06-2009, 09:01 PM   #15
I would highly suggest buying a set of these!http://xtreme-rc-hobbies.net/store/p...roducts_id=206
or another cheaper option I suggest these!http://xtreme-rc-hobbies.net/store/p...products_id=75
both are good options. I would not go with the aluminum as they will hang up on the rocks more and more as they get scratched up.
bigflex is offline   Reply With Quote
Old 07-06-2009, 09:03 PM   #16
all of you.
either of these guys links would work great too.
