Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: One of a kind Slingshot
Old 07-06-2009, 09:57 PM   #1
Default One of a kind Slingshot
Well i have been playin with the dremel again. I think when i get done i will be happy with it though. About the only major thing i need to do is limit the shocks to 3" so i can stand them up more. Also i need to replace the dig internals, just waitin on the postman. Well here goes i hope you like it.
It is a work in progress.
ubbb69 is offline   Reply With Quote
Old 07-06-2009, 10:23 PM   #2
That's a NARROW Slingshot! hope you can get it to working they way you want it.
bigflex is offline   Reply With Quote
Old 07-06-2009, 10:44 PM   #3
Do your upper and lower links hit against each other? It looks like at the slightest flex they would hit each other limiting your flex.
RustlerHustler is offline   Reply With Quote
Old 07-06-2009, 11:07 PM   #4
These pics are at full flex. As you can see there is not binding and it is smooth all the way to shock bottom.
Old 07-06-2009, 11:11 PM   #5
Hateraide
Code454's Avatar
you hould try to get chassis braces in there, but ya super narrow, hope it works keep us posted
Code454 is offline   Reply With Quote
Old 07-06-2009, 11:13 PM   #6
Some specs. Jato yellow springs front green rear 30wt oil. Out to out of chassie is 2". Also the upper and lower mounts are exactly the same as before i cut it. If you take a stock slingshot and measure the upper links when they are inside it is around 2" at the narowest spot. All the geometry is basicly the same as stock i just have less skid to pull over the rocks. I am at 12.5 wb and i am guessing 3" belly clearance. Stifners will be added after i pull it apart to repaint and get new hardware. Right now i just mocked it up to see if it will work
Old 07-06-2009, 11:20 PM   #7
TEAM BWD
chad30w's Avatar
Looking good i hope you get those shocks to work out better than what i am? I'm not really liking them right now, back to the coloring board cause i can't draw for sh!t.....LOl
chad30w is offline   Reply With Quote
Old 07-06-2009, 11:24 PM   #8
what is the problem with the shocks? IE to slow, to firm?
Old 07-06-2009, 11:37 PM   #9
Hey chad big sent me a pm saying to drill the pistons out to 1/8" which i did one to test. It works so much better now thanks. I only drilled one hole though just to see.
Old 07-06-2009, 11:40 PM   #10
TEAM BWD
chad30w's Avatar
Me too......I drilled one in fronts two in rears just to see I really think my problem is i need to lay them down more to get more travel
Old 07-06-2009, 11:48 PM   #11
Yeah your last rig had alot if i remember right. I always stick to about a soda can. Seems to work well after i got used to it. I am still up in the air on what elecs to use and i hate to buy wheels in ax offset when soon it will have berg axles if i like it. I think i may try tekin just for the better drag brake.
Old 07-07-2009, 06:13 AM   #12
1977
jpboy's Avatar
i got some wheels for you bro
jpboy is offline   Reply With Quote
Old 07-07-2009, 06:58 AM   #13
Gold Star Baby!
DARKHORSE's Avatar
It will never work.
DARKHORSE is offline   Reply With Quote
Old 07-07-2009, 07:35 AM   #14
You are the man.
And none of my rigs ever work.
Old 07-09-2009, 10:51 AM   #15
Decided to use the tekin in my berg so this rig is going to get a sidewinder. I am going to tear down and repaint it. As soon as i get it back together ill post it up.
Old 07-09-2009, 11:48 AM   #16
Let us know how you like the sidewinder I'm waiting for mine to show up
93yoda is offline   Reply With Quote
