Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Rear Steer on Stock Ax10 RTC
Old 07-07-2009, 01:45 PM   #1
Default Rear Steer on Stock Ax10 RTC
I was wondering if the ESC in the AX10 RTC can run two servos with a Y harness.
The servo I have is another Axial AS-2 I bought on eBay.
It will take me 2 weeks to get a Castle BEC and I am impatient.
Baldur is offline   Reply With Quote
Old 07-07-2009, 01:58 PM   #2
I joined the Band!
It might work but IMO Axial electronics suck and you would be wasting your time and money buying or using anything electronic from Axial. I have rear steering set up on my AX10 with a Y harness using two Futaba S3305 HT MG servos and it works like a champ. Novak is powering both servos.
grimgard is offline   Reply With Quote
Old 07-07-2009, 04:36 PM   #3
Devoted axle fan
MadForce's Avatar
You need a reverser for the rear otherwise you'll have crabsteer.
MadForce is offline   Reply With Quote
Old 07-07-2009, 04:41 PM   #4
the "my first craler vid" link in my sig has the stock esc running 2 mg645 servos running off it. i used a y harness and moded the rear servo to reverse it.
NeXt559 is offline   Reply With Quote
