| | #1 |
| Rock Crawler Join Date: Sep 2004 Location: eureka
| do squat numbers change, if you change the ride height ? changing the ride height changes the angle the links are at but does that change anything my guess would be no, but I am unsure. |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Apr 2009 Location: Crawlerado Springs
| | #3 | |
| Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
Edit: If you do not want the anti squat to change but raise your ride height, you could just put bigger tires on. Last edited by rc4x4crawler; 07-07-2009 at 10:53 PM. | |
| | #4 |
| got bigger tires and am now lowering the chassis . so as long as i move the upper links to keep the same angle they are at now, it should keep the same squat numbers |
| | #5 |
| It will change slightly just because of the weight distribution but you will probably not even notice if you compensate for the ride height. |
| Thread Tools | |
| Display Modes | |
