Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: my body posts like rocks help
Old 07-08-2009, 01:57 AM   #1
Default my body posts like rocks help
i got hung up on the rocks with the body posts at my last comp.. i tryed shortening them and that dont seem to cut it ...dose anybody know a vertical way to run the body posts pic's would be very helpful...thanks...
typeostyle is offline   Reply With Quote
Old 07-08-2009, 02:38 AM   #2
Devoted axle fan
MadForce's Avatar
Are we talking the standard plastic stuff? I drilled them on the side of the hexed portion with a 2.5mm drill and screwed them with self tapping screws in the unused shock mounting holes.
MadForce is offline   Reply With Quote
Old 07-08-2009, 04:10 AM   #3
abadk9420's Avatar
You could always do what I did and use Velcro Check out my build using the link in my sig and you will see the velcro body mounts that I made, Ruff surface Velcro works the best.
abadk9420 is offline   Reply With Quote
Old 07-08-2009, 07:14 AM   #4
Ckeck out www.eastendmachining.com for axial body mounts.
wheelstoo is online now   Reply With Quote
Old 07-08-2009, 07:18 AM   #5
i like the velcro idea but i'm not sure if it will work the rock we comp at is alot more sharp and jagged
Old 07-08-2009, 10:14 AM   #6
I have seen people using the mounts for the stock battery tray. If your not running the large tray on top you can put your post in the center holes of the plastic brace and run them vertically. You may need to modify the post so your lid doesnt sit so high. If you want to continue and run them on the side you can try shortening them and sucking the body in a lil, you might have to trim the bottom of your bodies a lil tho.
slimeball is offline   Reply With Quote
Old 07-08-2009, 12:02 PM   #7
ya i tryed shortening them dont seem to work very well and i am running the big bat..iam waiting for my saddle pack to show up along with my jet boat bta kit ...
Old 07-08-2009, 12:03 PM   #8
LIKES2CRAWL's Avatar
Little tip I noticed when running side posts is try to get them as high and close to shock/tire area as possable that helps them from getting hung up so much. I personaly use top mount posts or nylon accorn nuts/bolts.
LIKES2CRAWL is offline   Reply With Quote
Old 07-08-2009, 12:03 PM   #9
You can use dubro ones that are most hobby shops, and then just use a hole on the chassis or drill a new hole to attach. They will mount up and shoot upward, so it won't interfere with the rocks any more. I will see if I have any packs lying around at home and get the number off of.
tgh117 is offline   Reply With Quote
Old 07-08-2009, 01:46 PM   #10
if you're compin w/ it i assume you've done away with the original battery plate and brackets?
i flipped the brackets out, and screwed the mount posts into the existing holes.
like sooooo
BEELZEBOB is online now   Reply With Quote
Old 07-08-2009, 01:48 PM   #11
+1
Nor*CalDefender is offline   Reply With Quote
Old 07-08-2009, 01:49 PM   #12
like sooooo
*snip pic*
thats what I was trying to explain, but pics alway work better
Old 07-08-2009, 11:55 PM   #13
sweet...i dont think i would have thought of that...and the pic totaly helped alot...thanks..
