Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: BCCrawlerZ 2009 Comp Rig
Old 07-08-2009, 10:52 AM   #1
Default BCCrawlerZ 2009 Comp Rig
Finally got the new 09 comp truck finished and ready for its first comp this coming weekend..
SPECS
Chassis: Bender SWX
Axles: Axial axles with HD lockers, aluminum c hubs, CKRC high steer knuckles with BTA steering, Rear aluminum straight axles
Electronics: CC Mamba Sidewinder esc, CC BEC, Integy 45T motor, Hitec HS-7955TG Servo, Airtronics 2.4ghz controller and reciever, 3 cell 1300 mah lipos
Shocks: RC4WD 110mm dual rate shocks
Wheel and Tire: Proline 8 shooters with Panther Cougar tires
Body: Proline 1/10th Crawler Bug body
BCCrawlerZ is offline   Reply With Quote
Old 07-08-2009, 11:52 AM   #2
looks pretty good bud. Might I make a suggestion though? Cut the fenders off and slam that body down. It will really help squeeze through the tight spots and also it will make it alot easier to get back on its tires if you flop onto your lid. Other than that I really like what you have going on there.
bigflex is offline   Reply With Quote
Old 07-08-2009, 12:14 PM   #3
Hey.. Thanks for the tip man.. I will most likely be doing that as it does rub pretty good..
Old 07-08-2009, 12:31 PM   #4
no problem. Just remember that comp rules straight you need it to be at least 3" tall and 12.5" long. Other then that just do what you gotta do to get it down and clear of the tires.
Old 07-08-2009, 03:46 PM   #5
Default Cool Bug
Looking Good!
fernando is offline   Reply With Quote
Old 07-08-2009, 04:09 PM   #6
Default ;-)
looks nice
Rc Casper is offline   Reply With Quote
Old 07-08-2009, 08:25 PM   #7
looks sweet
GH Racing is offline   Reply With Quote
Old 07-08-2009, 09:39 PM   #8
That thing is too pretty to scratch up. Nice
oldhippie is offline   Reply With Quote
Old 07-09-2009, 01:10 AM   #9
I really like the paint scheme. And I am going to have to agree with bigflex it does look pretty tall (body wise) compared to most bug bodies on axail based rigs.
93yoda is offline   Reply With Quote
Old 07-09-2009, 07:05 AM   #10
Ya.. I already chopped the fenders off and lowered it.. Ill get some new pics soon!
Old 07-09-2009, 12:37 PM   #11
Did you have to cut into the motor area on the back?
Old 07-09-2009, 02:00 PM   #12
Not to bad! I agree! Slam that body. Lets see some naked pics to see how you have everything mounted...:-P
bayouhazard is offline   Reply With Quote
Old 07-11-2009, 09:32 AM   #13
Here are some action shots after cutting the fenders and dropping the body as far as I could..
Old 07-11-2009, 11:43 AM   #14
That looks pretty good man!
Have you had a problem with heeping those beads in those wheels yet?
Old 07-11-2009, 11:50 AM   #15
It took a few try's on mounting them to get them all stuck in there.. Will see how they hold up tomorrow at the comp!
Old 07-11-2009, 02:22 PM   #16
Awesome well good luck! Post more pics of the comp.
I won't be making our next comp due to my stripped tranny gears....
