| | #1 |
| Rock Stacker Join Date: Aug 2008 Location: Spring TX
| This is my crawler.... Built to go fast and crawl well. Its a little on the heavy side so im going to try to shead some weight...Iv'e still got a 60/40 weight spread ESC- Sidewinder with BEC Colbolt 10 turn with HR gears and Stage 3 (i think) hardened outputs Geared 25/87 with the overdrive gear in the front end 3s 2200 lipo on the rear axle Raido- DX3-S MIP shaft front and about to be rear as soon as I finish welding it 4 llink front and rear HB Rovers and eritex wheels CKRC dig...ya i know Losi 4 inch crawler shocks Iv'e got slingshot bent links on the rear which was done to shorten WB ![]() ![]() I had to knotch out the chassis quite a bit to fit the motor ![]() ![]() Custom drilled rear wheels. I know there not perfect (flame suit on) ![]() Triangulated 4 link ![]() Flex ![]() Electronics on front axle. I stacked the low cg plate on top of my 4 link plate so i could still run my 4 link. ![]() 2.5 gc ![]() How she sits. I like how I have the body mounted back, I love the way the front tires look pushed foward with the low stance ![]() Action shots ![]() ![]() Open to suggestions! Thanks for reading Chad Last edited by bayouhazard; 07-09-2009 at 06:56 PM. |
| Sponsored Links | |
| | #2 |
| Team Y-Town ![]() Join Date: Oct 2007 Location: Houston
| That looks nice Chad. Hows the motor liking the 25 tooth pinion? I'm sure the wheelspeed is great but hows the torque still? I like the drilled rear wheels, I'm jelous your getting to go to a comp a week. Not like you didn't get enough drive time before right. I will hold that dig for you if you are serious about it, you may have to move the trans forward when you switch out digs, but that will help with the motor clearance. Oh ya and did you drill the pinion for the motor shaft? |
| | #3 |
| Latest NorCalRCRC slave ![]() Join Date: Dec 2008 Location: San Mateo, CA.
| That is a pretty big pinion. I'm running a 10 turn, use a 12 tooth pinion, and I think the wheelspeed is pretty decent. Motor run hot much? |
| | #4 |
| Rock Stacker Join Date: Dec 2008 Location: Memphis, TN
| Another great SWX crawler, very clean wiring setup. |
| | #5 | |
I like the way the wheels look drilled lol. Ya theres a little Tuesday night rock crawling leauge here in Ohio. Ill be back on the 25th though. I had to drill out the pinion too. The pinion is a 21 tooth (my bad) and the motor gets just a bit warm but not hot. I am really interested in that dig but im not sure i can fit it if i have to move my tranny. Its already wedged in there lol! | |
| | #6 |
| | #7 |
| Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
| Cool looking rig. What foam are you running inthe Rovers? Also how much do your wheels weigh? I'm running the Pro-line 2 stage memory foams with less than 4oz and they don't fold enough...stock Axial wheels. |
| | #8 | |
Im running 0oz in the rear due to the fact that the battery is back there and in the front with my comp solids im running like 5 or 6 oz. I know its a lot but i had to make up for the weight on the rear to keep my rig balanced. I'm planning on running a smaller liter battery so after that Ill take more weight out. Im running the stock foams with vented wheels which seems to be perfect. These wheels are a tiny bit wide which helps the side wall from rolling under the rim. Each front wheel weighs: holy crap! 15 oz And each rear weighs 7 oz. But that battery weighs 6 oz. fully charged lmao jk I love how balanced it is. I can go up pretty steep grades, but i think that the whole truck weighs to much. Thats probably why those tires fold up nicely. Maybe since those tires are so old it allows them to fold up nicer too! lol | |
| | #9 |
| Rock Stacker Join Date: Jul 2008 Location: Spring
| looks really good and clean... looks mean with the tires sittin way out front... |
| | #10 |
| | #11 |
| Quarry Creeper Join Date: Jun 2009 Location: SF
| What shock oil are you running?? |
| | #12 |
| | #13 |
| I just ordered an SWX a DNA dig and have losi shocks for my once was tuber ax10. already 4 linked it but any advice on steering, suspension, ect would be great. have lipo's and NIMH 6 cells and running a Goat with a novak 55t brushed motor! Thanks! |
| | #14 | |
Just keep it as light as possiable, weight it with 60% of the weight over the front axle and 40% over the rear, make sure the suspention cycles freely with no binds. If you're going to un a 4 link you'll probaly need to find some upper links, I think the lower links will work as uppers depending on what 4 link plate youre running, I also think a 2.5 ground clearance works well with this chassis. Just take a good look at my setup and you should be fine due to the fact that this chassis works well already! Any exact questions feel free to ask me and Ill be glad to answer. Last edited by bayouhazard; 07-12-2009 at 08:26 PM. | |
| | #15 | |
Thanks alot! My tuber crawls like crud, I'll get back to you when I get stuck in the re-build to SWX! Thanks again! | |
| | #16 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| | #17 |
| | #18 |
| Hey I dont hit all the gates! Just some! The last comp I felt as I did pretty descent! |
| | #19 |
| Newbie Join Date: Oct 2008 Location: heavener,ok
| hay u need too get a real body haha jk nice rig man ....... |
| | #20 |
| Going to be using this body in the feature: http://www.prolineracing.com/p-699-c...k-crawler.aspx Today I'm going to be installing some hardened Robinson Racing steel gears in the tranny. The HR alum. ones suck! |
| Thread Tools | |
| Display Modes | |
