Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: BRPlatz's Custom Comp Tuber...Take 2
Old 07-09-2009, 06:48 PM   #1
Default BRPlatz's Custom Comp Tuber...Take 2
Hey guys this is the second attempt at a Comp grade homemade tuber by me.
Some of you may have seen my other tuber but this one is much better and better planned out with the link positions and such.
Anyway,
Custom Tuber Chassis
Stock 55turn motor
Castle Creations Sidewinder ESC
Castle Creations BEC
Stock servo (soon to be replaced)
Custom Made OTA Steering
Custom Made front and rear 4-link plates
Custom Made upper links w/ revo ends
TQ3 with matching reciever
Stock Beadlocks
HB Rovers (F-ing amazing)
Wheel weights etc
here are the pics from start of build to finish.
New Delrin skidplate!
HB Rovers are in!
Tuber almost done with the brazing
Another view
Custom made foams for the Rovers. 1/2" slices of stock foam on the sides of a full Proline memory foam. Seems to work nice for now.
Got all my tabs on
Test Assembly
PAINT, Holy crap, I didnt know it was neon orange lol
Partly assembled
New Stance
Out and about
Brplatz is offline   Reply With Quote
Old 07-09-2009, 08:25 PM   #2
Lower that thing down. It Would also look better if there were 2 down bars on the rear insted of 1. I still like it and I know you have put alot of hard work into that chassis.
That thing in the 12th pic looks like the Warthhog off of Top Truck Challange LOL
bayouhazard is offline   Reply With Quote
Old 07-09-2009, 09:09 PM   #3
I thought about dropping id down a bit also, what would be the best way to do that? Droop shocks? I am temped to do that
Old 07-09-2009, 09:32 PM   #4
Put internal stops inside the shock between the lower part of the shock and the shock plunger. Nitro fuel line works great for that
Old 07-09-2009, 09:52 PM   #5
Ah, ok ill try that next and see how it works.
Anyone else care to comment on it? I thought i did a pretty good job?
Old 07-09-2009, 10:03 PM   #6
ya man i will... it looks real good...
the bta steering looks interesting... do you get full throw each way??? are those plastic or derlrin lowers? i cant tell but if they are plastic i would suggest to go to derlin... it does sit a little high and i bet that chassis is decentally heavy so i would suggest trying half droop half sprung with the internal springs... you have to test and tune but i have noticed that most tubers run droop or at least some droop since they are top heavy... other than that man keep up the good work brazing is very hard and you did a good job on it...
Big D is offline   Reply With Quote
Old 07-09-2009, 10:05 PM   #7
Oh ya and don't forget the infamous 4" Losi crawler shocks. Those work great and will lower your shit too.
Old 07-09-2009, 10:52 PM   #8
Any more info on the droop or half-droop setup. Like what springs I should get, oils, etc?
Old 07-09-2009, 11:19 PM   #9
You could run shorter coil springs like t maxx springs with internal springs taking up the droop slop that way they will work like anti-roll spring therefore on a side hill you won't unload your suspention... Search around and you can find a good shock set up.
I still like the losi shock idea! LOL
Old 07-09-2009, 11:39 PM   #10
My shocks are the new Axial ones and I really like them, so I'll see if I can droop them.
And yes the links are plastic, but I just bought a DX3R and my next upgrade is a VP dig (exept shocks)
Old 07-10-2009, 11:51 AM   #11
Good luck! keep the pics up to date and pics on how you decide to do the shocks
Old 07-10-2009, 07:06 PM   #12
Update:
I did a kinda droop thing, I just took the shocks off. Seems ok but i still need to play with it a little.
Also i got some white and red LED's and mounted them in headlights and taillights. ill get them on the crawler soon for some nightime crawlin. as soon as i get some pics, ill post em
Old 07-11-2009, 06:55 PM   #13
So nobody has a opinion on this? Maybe this forum has something against tubers or something?
I would really like to see some helpfull insite on this crawler, anything is great.
Old 09-21-2009, 03:01 PM   #14
I realy like the tube body. Wish I could weld that way. Dont like whats in the stores for sale. BTW I want to lower my axial too. So I am thinking of fuel line inside or pensprings.
berg is offline   Reply With Quote
Old 09-22-2009, 08:16 PM   #15
I like it, . I dont think anyone here dosent like tubers, they just dont want to work hard enough to get them set right. Its taken me awile to get mine all dialed but I think It does awesome. Its also nice to know that you arent going to go to a comp and see someome else driving your truck, or anything even close.
Beest is offline   Reply With Quote
Old 09-23-2009, 12:28 AM   #16
I'm running the same foam-setup in my Rovers, and its awesome. Much better at sidehilling, and the grip on rocks really 'rocks'
I thought of replacing them with 2 stage foam, but I'm not sure its worth the effort.
stianl is offline   Reply With Quote
