Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Building a Vanquish AX10
Old 07-10-2009, 12:28 AM   #1
Default Building a Vanquish AX10
So if I wanted to build a ax10 with all the available vanquish products what is the easiest way to do it? Should you buy the kit or jut buy the tranny, axles, shocks? or what? Thanks a lot
C_Money is offline   Reply With Quote
Old 07-10-2009, 12:34 AM   #2
it would be easier to buy it all seperate you will not use most of the parts from the kit
Wicked_Jester is offline   Reply With Quote
Old 07-10-2009, 12:41 AM   #3
so what is a complete list of parts I would need minus electronics and all the vanquish parts so it will be comp ready? I would like to probly use aftermarket screws if they have them out there.
Old 07-10-2009, 12:58 AM   #4
mcmaster carr for screws. I was just working on my rig, so these came up in my head... could be different sizes for you tho. Vanquish chassis looks like it comes with cross brace/screws, and lower link at chassis hardware.
You'll most likely need these.
M3X25mm(for lower links at axles)
M3 Nylocks/locknuts
M3X14mm(for upper links at chassis)
that's all I got for now, don't think anybody can/will list every single thing you need for your build.
barbaricboye is offline   Reply With Quote
Old 07-10-2009, 01:08 AM   #5
well i hope someone will chime in and list it haha cause I have no idea all the parts i need. I want to go with white derlin links or titanium ones, more than likely white though
Old 07-10-2009, 03:57 AM   #6
abadk9420's Avatar
Well if you wanted to go all VP here is what I think you would need.
Vanquish Incision Pro AX-10 Chassis
VP High Steer Steering Knuckles
VP Rear Axle Lockouts
Vanquish Hurtz Shifter 3 Position Dig for Axial AX-10
Vanquish Products R-2 or Revolver DH ProComp 2.2
Aluminum C's from STRC or similar
Axial axles and transmission
abadk9420 is offline   Reply With Quote
Old 07-10-2009, 09:18 AM   #7
ok now what about other parts to complete like links axles and such
Old 07-10-2009, 11:32 AM   #8
Now where are you getting all this money at Mr. C Money? Ill be here for the C Money giveaway when you have one!
bayouhazard is offline   Reply With Quote
Old 07-10-2009, 01:59 PM   #9
haha its no more expensive than any other crawler, and I figure why not build it comp ready right? I will of course practice first since this will be my first real crawler but I have been around it before.
Old 07-10-2009, 03:51 PM   #10
I think you are doing it right. IMO it costs way more to start with a basic truck and upgrade, instead of just buying top notch off the bat. Have you tried sending a PM to one of the VP guys for a little insight into what you might need? As far as axles, I think you should look in the for sale section, and pick up some nice built ones. You should be able to get a pretty bulletproof set for around $100-$150.
Mayze is offline   Reply With Quote
Old 07-10-2009, 04:18 PM   #11
I wish I did what you are doing, would of saved me some $.... but then I probably wouldn't have learned as much, and appreciate the outcome/s of minor changes, etc.
as far as upper and lower links: ask VP what lengths they recommend to get a 12.5inch wheelbase(they should know if you are using their chassis+their axle plates)
if you are gonna piece your axles together(and don't know how they go together yet) I would suggest downloading, buying, or copying a axial manual for a visual reference.
axle upgrades: BOTH: felsenfast lockers(the only way to go)
alum. hexes
m4 locknuts(wheel to axle, not an upgrade-noting it)
stock bearings(or cheaper)
FRONT: overdrive r&p
I use stock dogdones/cup(hold up better than cvds)
"c's" axial, rcp, etc.
VP knuckles
BTA if you'd like
REAR: HD r&p or underdrive gears
I use stock straight inner axles(rcp steel ones work)
VP rear "lockouts"
probably missing stuff, maybe i'll add some later.
Old 07-10-2009, 06:06 PM   #12
ok so what about drive lines? what is the best way to go there? Is there any black driveline pin retainers out there?
Old 07-10-2009, 06:19 PM   #13
alum. hexes
VP knuckles
BTA if you'd like
VP rear "lockouts"
what do you mean by overdrive and r&p? is tht a brand?
also is the typical crawler wheelbase 12.5 inches or what?
Old 07-10-2009, 06:33 PM   #14
r&p = ring and pinion gears in the axles
think of it and putting taller or shorter axle gears in a 1:1
overdrive gears
http://www.shop.rpphobby.com/product...productId=1540
underdrive gears
http://www.shop.rpphobby.com/product...productId=1541
stock gearing but heavy duty
http://www.shop.rpphobby.com/product...&productId=575
as far as what you will need
from vp;
incision chassis
link plates front and rear
shock risers
knuckles
rear lockouts
other stuff
axial axles
mip cvd shafts
stainless steel straight shafts
axial transmittion
aluminum axle c's (axial or rcp are the top on the market)
traxxas stampede shaft halves
steel yokes
shocks (new axial's are a great choice)
I perfer mayhem wheels but you can choose what you like
Tires
body
misc hardware (nuts, bolts)
delrin or aluminum for links
link drill bushing for making your links
Link Drill Bushing
traxxas or axial rod ends
3x16mm set screw
body post
yes 12.5" is the maximum legal length for 2.2 comp use yotachump makes a very nice wheelbase jig to help you in making sure your axles end up lined up and square
*****CDW 2.2 Wheelbase Jigs*****
Old 07-10-2009, 06:43 PM   #15
ok what do you guys think he best R&P combos are for all around stuff for awhile? I am just going to ask a few questions at once and write down exactly what I need so I can take it with me when I buy.
Old 07-10-2009, 06:48 PM   #16
it comes down to personal preference
Im personally build an motor on axle (MOA) it eleminates the rollovers cause by the torque twist the shafty rigs have
and just because a product Is top of the line or works good for someone else doesnt make it the right product for you, some guys like a fast rig some like slow and more torque, some like a stiff suspension other like soft, some like taller tires others like shorter!
I would try the stock gears for a while and then determine if you feel the need to have more overdrive or underdrive!!
Old 07-10-2009, 06:51 PM   #17
interesting, well I think I will let a few others chime in on this one, feel free to answer any other questions I ask in the future.
Old 07-10-2009, 06:56 PM   #18
you wont beable to go out and buy everything on a parts list that one of us on the board make and be happy with it, I could make you a list of exactly everything you need to go buy and that would be a rig set up for my liking not yours, you would then change stuff you the way you like it like longer shocks, different springs, different shock oil, tires, foams, wheel weight, total rig weight, there is to many things to change to make a rig the way you like it and that fits your driving style
we can only help you get a basic rig going the you have to change parts and tune it so that it fits you
Old 07-10-2009, 07:06 PM   #19
I ran the o/u gears and they are awesome, the HD Stock ratio also are great, they hold up great! Also pm replied
axman2010 is offline   Reply With Quote
Old 07-10-2009, 07:47 PM   #20
I understand I will have to change but I dont mind, I am kinda just looking for a setup such as gears that a majority of the people use you know?
