08-08-2009, 06:48 PM | #1 |
Newbie Join Date: Jul 2009 Location: Pg
| Internal Shock
Anybody try this shock? How's the performance? http://cgi.ebay.com/Axial-Ax10-Scorp...d=p3286.c0.m14 |
08-08-2009, 07:13 PM | #2 | |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
Im skeptical on how theese would perform. Just my .02 | |
10-20-2009, 04:54 PM | #3 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
Has anybody tried these yet? Do they even dampen like a oil shock. I think they would look cool on my berg but I need them to work as good if not better then my traxxas big bores..
10-20-2009, 05:01 PM | #4 |
Newbie Join Date: Jun 2008 Location: Germany
I have two in the front of my AX10. But it works hmmmmmmmmmmm................ Oil is much better and smoother, but it looks better. cu |
10-20-2009, 05:32 PM | #5 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| They Work Great! I run these Air Shocks on my Comp Rig, and the work great for me. You will have to keep the shaft slick with some Green Slime. Reason being if you don't the shaft will lock up and start to damage the rubber ring inside the actual shock body. You can find the Green Slime lube at your local Hobby Shop. Hot Racing Air Shocks Are cool looking, and perform great. |
10-20-2009, 05:32 PM | #6 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
They're not air shocks if they where then the wouldn't have a spring inside them. They are just simple frictions shocks like the ones that come with the Tamiya High Lift.
10-20-2009, 05:44 PM | #7 |
10-20-2009, 07:30 PM | #8 |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
I bought two sets of those shocks....the first being the wrong length. However, I pulled them off not long after. They come with three different spring stiffnesses (is that a word?). After trying them all and even two springs per shock, I never was really crazy about the performance. Maybe it is because I'm a noob, but I like the chassis to straighten back up when I finish a turn and the springs weren't strong enough for me. I run aluminum HPI MT2 shocks now with 20wt oil and I like them much more. |
10-20-2009, 10:34 PM | #9 |
Pebble Pounder Join Date: Jun 2008 Location: The Crawler Dead State of NC
I bought a set of these used. They work okay, they are very smooth as long as you keep shafts lubed. I put about 5 drops of 30wt shock oil in them and they are butter smooth. Now for the bad news... I think they are too soft for a shafty. The springs in mine are soft. I wish I had the other spring rates to try. I think they may work better on an MOA.
10-21-2009, 12:13 AM | #10 |
Newbie Join Date: Mar 2009 Location: flint
yeha ive heard they arent too good if you have a loy of sprung weright as opposed top unsprung weight like on a MOA design, just jgets weighed down too much, or you could put mini quake springs in em if they are any stiffer
10-21-2009, 12:32 AM | #11 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
They look cool,but it is hard to beat a good set of oil shocks like the Axial Comp shocks.
