08-14-2009, 08:25 PM | #1 |
Pebble Pounder Join Date: May 2009 Location: Cincinnati
| Driveshaft rings issue
Put driveshaft rings on upper end of shafts and now contacts spur gear!Went to LHS and picked up an 81 tooth,but too small motor doesnt come in enough for proper mesh...Any ideas?Will an 85 tooth clear clear drive shaft rings,has anyone been through this?The 84 my LHS has is white and im picky!!Only black they have is 87,85,81....If anyone has been through this let me know what solved..I tried grinding down,but stii not enough clearance,and dont want to space trans up!!
08-15-2009, 07:14 AM | #2 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
Ditch the rings (at least the one near the gear) and get some Traxxas shafts. The pro-pack is like 6-9 bucks for 6 shafts. They are stronger but will fit the Axial yokes. Another option is to get an extended front output for the trans from Yotachump. (vendor on here) You can run a T-maxx shaft with one of these. I have one and it works well. |
08-15-2009, 09:24 AM | #3 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I used my lathe and put a chamfer on the ring so it wouldn't hit the spur when the suspension was fully compressed. I'm using the stock 87t spur. Last edited by dkf; 08-15-2009 at 09:27 AM. |
08-15-2009, 09:55 AM | #4 |
RCC Addict Join Date: Jun 2008 Location: Fresno
drop the rings and stock shafts invest in the mip c spline shafts and they'll be the last ones you'll ever buy. these things are bullet proof, ive yet to hear of anybody being able to break these. ive had mine about a year now and they besides haveing to replace my outdrives ive never has an issue w/ them. the outdrives ended up torquing an entire 90 degrees while the mips were still like new |
08-15-2009, 03:21 PM | #5 |
I prob will go with the c drives but for now i settled for a spray painted 84 tooth and chamfered the ring....
08-17-2009, 06:41 PM | #6 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
All you need is lock-tight blue and you will be golden. No need for rings or 3rd party shafts.
08-18-2009, 11:07 AM | #7 |
Newbie Join Date: Jan 2009 Location: Duluth
08-18-2009, 11:58 AM | #8 |
Rock Stacker Join Date: Jun 2009 Location: Cameron Park
Im running stock drive shafts with a 45t integy with 12/90 gearing and I haven't managed to mangle one yet (stretched a few but none broken) Just make sure they are tight and the ears are in good condition and you won't have a problem IMHO.
08-19-2009, 02:12 PM | #9 |
Mine ripped down the splines but i am tough on them...Get in bind,use motor to force out...I am running pede shafts with all four rings now.Went to a 84 tooth spur and chamfered the ring...No issues now!Thanks for ideas though..If loc tite is all your using and they hold together your being to easy!Go out and give that thing hell!See if you can break anything,fun to work on..I ran out of things to upgrade right now,so i break stuff to have reason to work on it!!Now go break s**t!
08-19-2009, 05:20 PM | #10 |
Pebble Pounder Join Date: Apr 2009 Location: Renton
the stock ears are weak, I like the mips. They have been taking a beating with my super bent links in the back and still going strong. I do have a stock back-up set though ready to go with the rings on just in case, though I have yet to require them. SS |
