Thread: Stripped out tranny gear and Spur, Metal ?
Old 08-17-2009, 11:27 AM   #1
toy4crawlin's Avatar
Default Stripped out tranny gear and Spur, Metal ?
Where do you find a metal 90t Spur gear for the Axial tranny ?
I upgraded to Yotachumps Chromoly output shafts, after 5 packs I blew the tranny idler gear so I upgraded to Robinson metals internals
Now I have stripped the Spur gear
If I need to drill the funky 3 holes in the spur < I am fine with that.
I am relatively pleased with this small mighty tranny for my 11lb scale super , But a 2 speed would be a lot of Fun to have.
thanks
toy4crawlin is offline   Reply With Quote
Old 08-17-2009, 12:43 PM   #2
this is all I could find...
http://www.hpiracing.com/optionparts/op-spur.htm
http://www.tcscrawlers.com/Integy-He...8-p-17293.html
http://www.ckrccrawlers.com/shop/ind...oducts_id=1076
http://www.robinsonracing.com/catalog/48pitchspur.html (may be plastic)
http://www.shop.rpphobby.com/product...categoryId=166
or you can always try a slipper:-(
hope this helps.
TOMCAT18T is offline   Reply With Quote
Old 08-17-2009, 03:33 PM   #3
I was looking for 90t, but at least i know who to ask now thank you
Wow what did you use to search for those results ?, I did not find them
TCS has the complete set in STEEL But it DOES NOT say what Size. :?
CKRC is 88t Aluminum is good at $3.40 in shipping
RPP is 88t Alum. wants $8. to ship
I did find the HPI, but unsure how strong the carbon gears are, become brittle.
Robinson gears are tempered plastic, use to be Delrin. I have no data on this plastic
Old 08-17-2009, 03:53 PM   #4
Picky Fab'r/Acetal Junky
Offroader5's Avatar
This site has alot of gears...in nylon, delrin, and aluminum, and in different pitches. You will have to drill your own holes...but you said that wasn't an issue.
http://www.servocity.com/html/hub_mount_gears.html
Offroader5 is offline   Reply With Quote
