09-17-2009, 12:47 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Ottawa
| axial vs. losi springs
Hey I just got a set of the losi shocks for my ax10. It comes with all white springs, and was wondering a few things. I know it is ideal you you get a harder spring on the LR for torque twist. Does anyone know if my stock axial kit springs are harder then the losi whites? Also what shock fluid does one recommend? 15,20,25 weight? all the same in all 4 shocks? Thanks! Dylan |
09-17-2009, 01:03 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
i run a traxxas red or a losi yeller in the back left i run 20wt up front and 30wt in the ass. purdy sure the axial springs are too long and stiff (RTR type) for the losi shocks |
09-17-2009, 01:31 PM | #3 |
RCC Addict Join Date: Jun 2008 Location: Fresno
the stock axial srings are waaaaaaayyy too hard for crawling. go w/ either the losi pink or yellow
09-17-2009, 01:34 PM | #4 |
Rock Stacker Join Date: Jun 2009 Location: Sacramento
X2 on the AX10 springs being too long. I just tried this last night and the ax10 springs are 3/4" longer and way too stiff. I have some axial super soft springs and they were still too long and stiff for the Losi shocks. The Losi spring pack options are nice but I was able to get a set up by just adjusting the spring down but each chassis will be different. 55wt in the rear and 35 in the front works for me.
09-17-2009, 06:10 PM | #5 |
thanks guys!
09-18-2009, 01:37 AM | #6 |
Quarry Creeper Join Date: May 2008 Location: Clarkston
Losi: Axial: AX30213 Spring 14x90mm 1.32 lbs/in - Super Soft (Red) AX30214 Spring 14x90mm 1.71 lbs/in - Soft (White) AX30215 Spring 14x90mm 2.25 lbs/in - Medium (Green) AX30216 Spring 14x90mm 2.78 lbs/in - Firm (Yellow) AX30217 Spring 14x90mm 3.01 lbs/in- Super Firm (Blue) You can cut the axial springs to fit shorter shocks. Also, all of these arenīt industrial quality springs. Equal springs might be different in springrate since they are hobby-quality. So it all comes back to trial and error. |
09-18-2009, 05:02 AM | #7 |
Newbie Join Date: Sep 2009 Location: s.e. michigan
hey uli thanks for the specs. thats very helpfull.
09-18-2009, 06:01 AM | #8 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Also if you go with underdrive or overdrive gear set in the front or rear, it will eliminate alot of the torque twist.
09-18-2009, 07:37 AM | #9 |
09-18-2009, 08:46 AM | #10 | |
umm that's not really up to date. i know for a fact that the pink now comes in in the 2.75 size and they also now have the gold which is 2.75 and set at 1.5 lbs as for cutting springs i'd highly sugest against it. it kinda like cutting the springs in a 1:1. its way to easy to botch a spring if you dont have exact mesurements of an uncoiled spring. it may be a miniscual mistake but in crawlers a little tends to count for a lot. | |
09-18-2009, 09:21 AM | #11 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
I run whites up front and yellows in the rear the losi shocks have the adjuster and i crank down the left rear till i find a happy medium
09-18-2009, 09:44 AM | #12 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
09-18-2009, 09:52 AM | #13 |
lol its a good reason to drop $30 on the optional gear sets lol
09-18-2009, 01:58 PM | #14 |
Quarry Creeper Join Date: Apr 2009 Location: Ukiah
I run the overdrive gears up front. They might help with TT a little, no more than the right springs will. I do like the OD gears though.
