09-18-2009, 08:02 AM | #1 |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
| Robinson Racing Spur 48P 93T & 96T for AX10?
Hi, Does anyone know the diameter of Robinson Racing Spur gear 48P 93T & 96T for AX10? I found they have the same diameter (47.9mm, 1.9") in towerhobbies, is that correct? Thanx! |
09-18-2009, 09:10 AM | #2 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
The stock 87t is 46.46mm in diameter while the 90t is 49.98mm. The 96t is 52.23mm inside the plastic bag so I guess around 52.18mm without the bag. If you are planning to get a replacement spur then go for them. They are seriously tough to strip.
09-18-2009, 10:03 AM | #3 |
Thank you MadForce. I remember some other post mentioned about long out drive shaft (for AX10 tranny) to avoid spur gear rubbing, do you know where can I get it? Thanx! Last edited by kc092755; 09-18-2009 at 10:09 AM. |
09-18-2009, 10:14 AM | #4 |
Crawler Design Works, formerly Yotachump used to make these but not anymore. There are some people putting a list together to convince him run another bunch of these myself included. If you think you might need a set you can find the thread in the vendors section under axles and tranny. His outputs had a 6mm shaft.
09-18-2009, 10:22 AM | #5 |
Thank you very much MadForce.
09-18-2009, 02:39 PM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
I have a Robinson Racing Spur gear 48P 93T and it just hits my mip shaft yoke. Clearanced itself and is holding up great. The 96t may clear a stock yoke but I don't know. |
09-18-2009, 02:54 PM | #7 |
The 96t only clears stock yokes. With the junfacs I use I can clear up to 93t with less than a cigarette paper space.
09-18-2009, 05:13 PM | #8 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Not sure I would be able to fit a 96t with the traxxas pede yokes. They are the same size as the stockers. The 93t pretty tight. Also they are not a direct fit. You have to dremel off the 3 posts on the plastic spur adapter. No big deal, just saying you have to. Kieren |
09-18-2009, 08:02 PM | #9 |
Thank you all for the info. I checked with RRP, 90t dia. is 1.916 inch (48.7mm) and 93t dia is 1.979 inch (50.3mm). |
