10-06-2009, 10:08 AM | #1 |
Newbie Join Date: Oct 2009 Location: fontana
| Uphill good-Downhill bad!!!!
Hi! I have this axial scorp w/Novak rooster esc & 55t motor w/ 14t pinion everything else stock. Runs great uphill but is still jerky going downhill.This thing should crawl great by now shouldnt it?
10-06-2009, 10:16 AM | #2 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
What do you mean "jerky"? Tha rooster has a drag brake that should creep going down hill. If it doesnt, it might be your throttle foward setting.
10-06-2009, 10:19 AM | #3 |
Quarry Creeper Join Date: Aug 2009 Location: Phoenix
What do you mean by jerky? Going down hill everytime you let off the trigger it will stop with the drag brake. This is by design. It will get better with driving practice and working on your setup. Have you added any weight yet? |
10-06-2009, 10:24 AM | #4 |
When i crawl downhill it jumps forward & rolls. no control downhill. have brake setting on.
10-06-2009, 10:37 AM | #5 |
More info needed. Has it always run this way? What Tx/Rx are you using? When I first installed my rooster, my throttle foward was causing the drag brake to not engage. It would just roll down hill. I dialed the setting back enough that the drag brake could function properly. You might also want to reprogram the esc just to make sure. |
10-06-2009, 10:46 AM | #6 |
Pebble Pounder Join Date: Jan 2009 Location: Helsinki, Finland
Too high center of gravity or loss of speed could be the major problems.
10-06-2009, 11:03 AM | #7 |
RCC Addict Join Date: Jun 2008 Location: Fresno
a vid of what your talking about would help alot. otherwise crawling downhill is a totally different skillset in crawling and lots of people have dificulty w/ it. |
10-06-2009, 11:10 AM | #8 |
Pebble Pounder Join Date: Jun 2009 Location: Finland
More weight in the rear axle, then it should be runnin better downhill.
10-06-2009, 11:29 AM | #9 |
Newbie Join Date: Dec 2008 Location: Boston
I had the same issue and found that my son had messed with the settings on my Specktrum DX2.0 radio. After futzing about with that for about an hour I finally got it corrected. Not sure if that'll help you but thats where my issue lay.
10-06-2009, 03:45 PM | #10 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
sounds like trim or glitching issues, try reprogramming the ESC, & check the trims on your radio. Make sure the rx antenna is not damaged. hope this helps |
