10-18-2009, 02:21 PM | #1 |
Newbie Join Date: Sep 2009 Location: Prescott Valley
| Starting a AX10 build.
Hello, I have a stock AX10 RTC right now, and its time to start putting some parts into it. So far I got a couple questions, Then I will get a list of things I am thinking of getting. For the high clearance links.. Is there a benefit to getting them for both front and back? I was going to get the aluminum Axial color pack, And it comes with only 2 high clearance links. So whats the deal there? 4 link set-up, I know it help eliminate torque twist, But how does it? And should I do both front and back, or just one? Those are the questions I have right now, I'm still looking at everything so I'm sure more will come up. Thanks, Cody. |
10-18-2009, 03:05 PM | #2 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
i only have my rear 4 linked an the bent links need to go on the rear thats what get hung up. if your looking at a chasis the black widow is a great cheep chasis at 39 bucks
10-18-2009, 06:51 PM | #3 |
Newbie Join Date: Mar 2009 Location: flint
if you feel creative theres a user on here ( i think his name i s binary terror) has the diagram for the rear, and multiople fronts. it does get more of an advantage from the rear, but front just makes it more solid imho
10-18-2009, 07:04 PM | #4 |
Ok thanks for the help. Im looking at a ESC and motor now. At first I was going to go with Tekin FXR with the 35t or 45t. But I'm thinking of getting a Sidewinder or MM instead. Also what motors do you recommend besides the Tekin, Is there anything else good too? And should I go 35t or 45t? |
10-18-2009, 09:53 PM | #5 | |
Quarry Creeper Join Date: Apr 2008 Location: Houston
10-18-2009, 11:40 PM | #6 |
RCC Addict Join Date: Jan 2007 Location: San Jose
search and read and you will find your answers in detail. you can also search pirate too.
10-19-2009, 09:30 AM | #7 |
Newbie Join Date: Jun 2009 Location: Woodstock
I'd go with the novak rooster and a 55t integy with say a 18 tooth pinion so u still got good torque and u still have decent wheel speed. |
10-19-2009, 08:25 PM | #8 |
After quite a bit of research here is a order I made from A Main. The next order will have to wait 2 weeks, Out of R/C money for the month. And most of it I have to get from TCS. 1 x AXIA1407 Axial Scorpion Color Pack (Green) 1 x NOV3545 Novak Forty-Five Crawler Brushed Motor (45T) 1 x CSESDW Castle Creations Sidewinder 1/10th Scale Sport Brushless ESC 1 x CSEPHXL Castle Creations Castle Link USB Programmer Adapter 1 x CSECCBEC Castle Creations 10 Amp Adjustable BEC 2 x PRO1149-14 Pro-Line Chisel 2.2" G8 Truck Tire w/Memory Foam (2) 2 x PRO2713-05 Pro-Line Titus 2.2" Black/Black Bead Loc Wheel (2) |
10-20-2009, 02:04 AM | #9 |
Newbie Join Date: Jan 2008 Location: Christiansburg, VA
If you ever want a dig setup, definitely look at the Vanquish unit. I just installed one in my ax10, and its working great
10-20-2009, 05:00 AM | #10 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
Or save some bucks and get spanking new DNA dig for cheap. Look in vender section under axles and tranny.
10-20-2009, 01:53 PM | #11 |
10-20-2009, 05:10 PM | #12 |
Rock Stacker Join Date: Nov 2008 Location: Streetsboro
Good choice on the ESC/motor.
